nivekdodge |
Member ![]() ![]() Group: Members Posts: 310 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region ![]() ![]() |
I was just wondering how well the 123 distributor temp gauge works. If you have both have you noticed?
Kevin |
Brian Fuerbach |
Member ![]() ![]() Group: Members Posts: 119 Joined: 1-July 19 From: Orange, Ca Member No.: 23,266 Region Association: Southern California ![]() |
I was just wondering how well the 123 distributor temp gauge works. If you have both have you noticed? Kevin I have measured the temp of the distributor housing with a Raytech IR non contact thermometer and it was within a few degrees. I would say pretty accurate. |
nivekdodge |
Brian
Mine is running at about 175 is that where yours is? Kevin |
Porschef |
How you doin' ![]() ![]() ![]() ![]() Group: Members Posts: 2,180 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States ![]() ![]() |
Wow, never tried this, now I’m curious to see how it compares to the dipstick gauge and the console temp gauge (IMG:style_emoticons/default/beerchug.gif)
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,818 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
Are you reading the temp on a Bluetooth 1-2-3 ?
mgphoto |
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,375 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California ![]() |
The temps are different, the 123 displays the temperature of the distributor, the cabin gauge reads oil temperature as does the dipstick which can go much higher than the 210* where the 123 operates between 175 and 210*F.
Porschef |
Yes, now I do remember there being a potential problem with them running too hot, although I’ve never had an issue with that
nivekdodge |
Yes I am trying to see where too hot is for the engine with the temp of the distributor and how that compares to the rest of the motor. What is too hot for a type4?
Kevin |
nditiz1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,262 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region ![]() ![]() |
Too hot is when your heads are cooking past 400. Stop reading oil temps and get a CHT under #3 plug.
Lo-Fi Version | Time is now: 15th July 2025 - 03:20 AM |
