| seanpaulmc |
Feb 8 2023, 05:28 PM
Member ![]() ![]() Group: Members Posts: 464 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States
Has anyone had success fixing a bad contact (male spade) on the 914's relay board?
Hats off to you folks that clean and refurbish these boards for others. (IMG:style_emoticons/default/pray.gif) I have a lot of hours in cleaning up this board and with finding this bad connector (material loss) I'd prefer to fix it and move forward rather than finding another board and starting over. I've done continuity checking on everything and the board is in good shape and cleaned up relatively well otherwise. I suspect these spade connectors can be un-soldered and pushed out the back. Can anyone verify that? And where to get a duplicate replacement piece? ![]() ![]() ![]() And, after some judicious cleaning... Odd that it's only one of the four that is bad. ![]() ![]() As always, thanks in advance. -Sean |
| JamesM |
Feb 8 2023, 07:23 PM
Caretaker of 914s - Master of Fuel Injection ![]() ![]() ![]() ![]() Group: Members Posts: 2,319 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Have multiple board that failed at the 4 pin connector to the ECU, usually the pin that grounds the fuel pump relay.
I think I have the latest one fixed but havent driven the car enough to know for 100% sure. Examining a couple it almost looks like they were never soldered properly (cold joint) and that corrosion and pressure from the connector over time caused it to fail. |
| r_towle |
Feb 8 2023, 07:39 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Dremel with a pin grinder on it?
| Geezer914 |
Feb 9 2023, 07:05 AM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,362 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
Use an emery board that the wife uses to file her nails.
| Superhawk996 |
Feb 9 2023, 08:39 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,105 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
If you’re really worried about it, desolder the old terminal from the bottom. Use a solder sucker and copper braid to remove all traces of solder. Find appropriate male spade terminal - modify to fit board. Solder back to the trace.
Lo-Fi Version | Time is now: 4th October 2026 - 12:52 PM |
