> New Engine tin source?
tshih914
post Feb 12 2023, 06:00 AM
I am starting to reassemble my 1975 2L engine after tearing it apart 20 years ago. As it has been a long while since I started the teardown, I don't remember where and what all the pieces are. It would be awesome if anyone would send/post me a photo showing all the pieces and where they go (of the complete engine tins). Even better if anyone could tell me if a source of aftermarket engine tins can be found.
Thanks in advance,
Tom
JeffBowlsby
post Feb 12 2023, 07:14 AM
New Carbon fiber tin is available but it’s $$$$$
brant
post Feb 12 2023, 07:46 AM
Buy a Haynes manual
zoomCat
post Feb 12 2023, 09:57 AM
Check page 197:
http://p914-6info.net/PDFs/Group%201%20Engine%20914-4.pdf
914werke
post Feb 12 2023, 12:09 PM
No source for new. Best is to figure out what you have & fill in the missing.
Since many of the parts were shared with the T2 motor there is no need to reproduce them. Unless you have $ to burn & are looking for the Bling effect...
I understand that The T4 store has CF units?
BTW I just posted this shortly ago to a similar request (IMG:style_emoticons/default/rolleyes.gif)
930cabman
post Feb 12 2023, 03:09 PM
There is plenty of old stuff floating around, might need to move the location of the spark plug holes if 1.8 top tin is all that's readily available
Good luck with the build, will she be stock?
r_towle
post Feb 12 2023, 04:43 PM
Custom Member
QUOTE(JeffBowlsby @ Feb 12 2023, 08:14 AM) *
Who sells that?
Rich
Superhawk996
post Feb 12 2023, 04:52 PM
QUOTE(r_towle @ Feb 12 2023, 05:43 PM) *
Who sells that?
Rich
Hit the lottery? Don’t forget us!
https://lnengineering.com/raby-s-aircooled-...ne-tin-kit.html
914werke
post Feb 12 2023, 05:01 PM
"are not plug and play as the bolt and screw holes are not pre-drilled on the shrouds and will have to be added during the installation process"
For that princely sum you'd thinks they were complete & delivered wrapped in silk (IMG:style_emoticons/default/biggrin.gif)
r_towle
post Feb 12 2023, 06:02 PM
Custom Member
I can’t imagine brand new steel would be cheaper
bkrantz
post Feb 12 2023, 08:21 PM
And think of the enormous weight savings!
cgnj
post Feb 12 2023, 10:13 PM
QUOTE(914werke @ Feb 12 2023, 04:01 PM) *
And installed
To op Find cylinder head tin Part 1&2 I'm local and can help you with the other pieces
CCE
post Feb 13 2023, 08:48 AM
CCE
If money is not an issue.make it carbon fiber…
VaccaRabite
post Feb 13 2023, 09:06 AM
En Garde!
QUOTE(914werke @ Feb 12 2023, 01:09 PM) *
When you put the tin back on REMEMBER, pieces 5 and 5a need to go on before the pushrod tubes are installed. I don't think you can install them with the tubes installed. Often they are just left on the motor.
Zach
tshih914
post Feb 15 2023, 05:55 PM
QUOTE(930cabman @ Feb 12 2023, 01:09 PM) *
The engine is going to be stock except for minor modifications to 1974 specs (delete air pump from 1975 CA emission). I will look for the parts which have been moved over the years. I have purchased a new cam shaft that's NOS and have put in the stronger con rod bolts. Waiting for Andrade Tabari to modify my valve train to accept 10 mm swivel feet rockers.
tshih914
post Feb 15 2023, 05:58 PM
QUOTE(VaccaRabite @ Feb 13 2023, 07:06 AM) *
Zach
Thanks for the heads up. Those pieces are what I was looking for and as I recalled they go at the bottom of the cylinders above the pushrod tubes.
tshih914
post Feb 15 2023, 06:34 PM
QUOTE(tshih914 @ Feb 15 2023, 03:58 PM) *
Zach
Found a box containing piece #1 and 27 in addition to the alternator and piece of the fuel rail.
TJB/914
post Feb 15 2023, 06:41 PM
Mid-Engn.
QUOTE(tshih914 @ Feb 15 2023, 07:34 PM) *
Zach
tshih914
I think I have some of the lower tin pieces that's off a 1974 1.8 motor.
Question from the experts? Is i.8 tin the same as 2.0??
Tom
tshih914
post Feb 15 2023, 06:47 PM
QUOTE(tshih914 @ Feb 15 2023, 04:34 PM) *
Zach
The fuel rail at one end a part was cut off. Is that the fuel pressure regulator?
Krieger
post Feb 15 2023, 07:03 PM
That is your air injection system. The one way valve is cut. This is smog equipment. It looks like the air pump that feeds it is in the box below it.
- Lo-Fi Version Time is now: 7th December 2025 - 10:19 AM
