914 RZ-1 |
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 684 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California ![]() |
1. I need to press in the front wheel bearings. Can I just use a big socket and tap/hit them in? Is there a better way? I do not have a press.
2. What do I grease? I'm assuming a pack it in the bearings, but do I put grease anywhere else? Do I pack these before or after I press them in? ![]() ![]() Thanks! -Jeff --------- |
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
I'd scotch brite the new bearing bores and install with an old school wheel bearing race installation tool like this
https://www.harborfreight.com/bearing-race-...iece-63261.html That ones a bit expensive. Check amazon. I have used the old bearing race many times in the past. Sometimes it's tricky to get it back out. A socket will work as well but it needs to fit the bore closely as the edges of most sockets are rounded and you can chip a race if not careful. The bearings need to be packed either by hand or with a tool. https://www.youtube.com/watch?v=BhL1uAp_WCw https://www.amazon.com/Lisle-34550-Handy-Pa...g/dp/B0002NYDYO. I will half fill the interior between the two bearings. This grease may never get used but it is there for a possible overheat. Leave plenty of space for expansion as I've seen overpacked hubs pop the inner wheel seal out before. |
iankarr |
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,567 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region ![]() ![]() |
Hope this helps...
https://www.youtube.com/watch?v=qCglV8Ttp_s And you can definitely use the Harbor Freight bearing press kit. I use that now instead of the old race... |
scott_in_nh |
Senior Member ![]() ![]() ![]() Group: Members Posts: 809 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States ![]() |
The tool is obviously the best way, but if you use an old race make a cut through it with a cut off wheel.
This allows the old race to be easily removed... |
technicalninja |
BK911 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None ![]() |
Bearing races can be "pressed" in using a nut and bolt with appropriately sized washers.
mgphoto |
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,375 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California ![]() |
You will need to press the grease into the bearing, there is a tool but it’s easy to pack it by hand. I use latex gloves, put a glob of grease in the palm of your hand, push the bearing into your palm, get another glob of grease with your fingers and rotate the bearing through your palm pushing the grease between the rollers and the cage, saturating the bearing is extremely important.
After pressing in the races, fill the inner section of the hub, between the races with some grease, I use a moly lube called BR2, but most axle grease will work fine. |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,177 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
You will need to press the grease into the bearing, there is a tool but it’s easy to pack it by hand. I use latex gloves, put a glob of grease in the palm of your hand, push the bearing into your palm, get another glob of grease with your fingers and rotate the bearing through your palm pushing the grease between the rollers and the cage, saturating the bearing is extremely important. After pressing in the races, fill the inner section of the hub, between the races with some grease, I use a moly lube called BR2, but most axle grease will work fine. Exactly, make sure to clean the new bearing prior to greasing. |
mgphoto |
You will need to press the grease into the bearing, there is a tool but it’s easy to pack it by hand. I use latex gloves, put a glob of grease in the palm of your hand, push the bearing into your palm, get another glob of grease with your fingers and rotate the bearing through your palm pushing the grease between the rollers and the cage, saturating the bearing is extremely important. After pressing in the races, fill the inner section of the hub, between the races with some grease, I use a moly lube called BR2, but most axle grease will work fine. Exactly, make sure to clean the new bearing prior to greasing. DO NOT USE COMPRESSED AIR DURING CLEANING PROCESS. |
infraredcalvin |
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,655 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California ![]() ![]() |
Nobody freezes these anymore? Prep the bearing and put it in the freezer for a few days, take it out and quickly insert it into the rotor/hub. Tap in with socket or old race, etc. it will go in pretty easily.
Warm up the rotor hub a bit to make it easer but once the cold bearing hits the warm rotor it’ll start expanding quickly. |
914 RZ-1 |
You will need to press the grease into the bearing, there is a tool but it’s easy to pack it by hand. I use latex gloves, put a glob of grease in the palm of your hand, push the bearing into your palm, get another glob of grease with your fingers and rotate the bearing through your palm pushing the grease between the rollers and the cage, saturating the bearing is extremely important. After pressing in the races, fill the inner section of the hub, between the races with some grease, I use a moly lube called BR2, but most axle grease will work fine. Thanks! I think I get what to do. One questions/clarification: Why am I filling in between the hubs? There's nothing there, is there? Nothing rolls on the axle. Just curious? |
Van B |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,621 Joined: 20-October 21 From: WR, GA Member No.: 26,011 Region Association: None ![]() ![]() |
Nobody freezes these anymore? Prep the bearing and put it in the freezer for a few days, take it out and quickly insert it into the rotor/hub. Tap in with socket or old race, etc. it will go in pretty easily. Warm up the rotor hub a bit to make it easer but once the cold bearing hits the warm rotor it’ll start expanding quickly. (IMG:style_emoticons/default/agree.gif) I have a 20 ton shop press but I still prefer deep freeze overnight for the race and a little torch action or oven on the housing. Nothing more satisfying than that sound of a race dropping home with zero banging. |
914 RZ-1 |
Hope this helps... https://www.youtube.com/watch?v=qCglV8Ttp_s And you can definitely use the Harbor Freight bearing press kit. I use that now instead of the old race... It did, thanks! I've done this once, a long time ago and need a refresher that is specific to a 914. |
930cabman |
Nobody freezes these anymore? Prep the bearing and put it in the freezer for a few days, take it out and quickly insert it into the rotor/hub. Tap in with socket or old race, etc. it will go in pretty easily. Warm up the rotor hub a bit to make it easer but once the cold bearing hits the warm rotor it’ll start expanding quickly. (IMG:style_emoticons/default/agree.gif) I have a 20 ton shop press but I still prefer deep freeze overnight for the race and a little torch action or oven on the housing. Nothing more satisfying than that sound of a race dropping home with zero banging. (IMG:style_emoticons/default/agree.gif) i do not have a shop press, but having expansion and contraction do the work is the cats meow |
914 RZ-1 |
I removed the old ones from the late rotor, cut them and used them to press the new races in place (like in the video). I used a big impact socket and a piece of steel rod as well. The cut allowed me to squeeze it with pliers or use a screwdriver to get it out after it seated the new race.
I didn't want to buy a $40 tool set I'd use infrequently. I have a lathe; maybe I'll make a tool for next time. I didn't want to spend the time this time since I need to get this done so the wife can have the garage back. Thanks everyone! (IMG:style_emoticons/default/beerchug.gif) |
mgphoto |
You will need to press the grease into the bearing, there is a tool but it’s easy to pack it by hand. I use latex gloves, put a glob of grease in the palm of your hand, push the bearing into your palm, get another glob of grease with your fingers and rotate the bearing through your palm pushing the grease between the rollers and the cage, saturating the bearing is extremely important. After pressing in the races, fill the inner section of the hub, between the races with some grease, I use a moly lube called BR2, but most axle grease will work fine. Thanks! I think I get what to do. One questions/clarification: Why am I filling in between the hubs? There's nothing there, is there? Nothing rolls on the axle. Just curious? The heat in the hub will flow the grease from the center to the bearings, use just enough grease, use the rubber seals under the dust cap to contain the mess. |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,744 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
I removed the old ones from the late rotor, cut them and used them to press the new races in place (like in the video). I used a big impact socket and a piece of steel rod as well. The cut allowed me to squeeze it with pliers or use a screwdriver to get it out after it seated the new race. I didn't want to buy a $40 tool set I'd use infrequently. I have a lathe; maybe I'll make a tool for next time. I didn't want to spend the time this time since I need to get this done so the wife can have the garage back. Thanks everyone! (IMG:style_emoticons/default/beerchug.gif) That is what I did last week. Welded the 2 old races together then turned one of them down ~.010". ![]() ![]() |
Lo-Fi Version | Time is now: 19th July 2025 - 11:28 AM |
