1.7 Muffler, Is this trash or does someone want it? |
Highland |
Feb 19 2023, 03:42 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
I'm not sure if someone can use this muffler or should it go in the trash. Attached pictures for assessment. It came off a running car.
Free for pickup, North county San Diego. |
bzettner |
Feb 19 2023, 10:32 PM
Member Group: Members Posts: 211 Joined: 2-June 13 From: San Antonio, TX Member No.: 15,951 Region Association: Southwest Region |
It appears to have a hole/rusted out area/tear in it. (IMG:style_emoticons/default/blink.gif)
I’d say it’s junk (IMG:style_emoticons/default/beerchug.gif) |
Highland |
Feb 20 2023, 05:17 PM
Superhawk996 |
Feb 23 2023, 10:04 AM
914 Guru Group: Members Posts: 5,916 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Are most 1.7 components like tins, intake runners, pistons and cylinders, and heads junk too? I'm sure everyone has a spare set in their garage. What do you all do with them? Learn to weld - make art / yard art Tin can be converted to 2.0l tin by those in need. Heads - if no one wants them - use as practice - learn to replace valve guide, do a valve job before it matters. If you have a welder - learn to weld on heads or how to remove valve seats? (IMG:style_emoticons/default/confused24.gif) |
JamesM |
Feb 24 2023, 09:18 AM
Senior Member Group: Members Posts: 1,922 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Are most 1.7 components like tins, intake runners, pistons and cylinders, and heads junk too? I'm sure everyone has a spare set in their garage. What do you all do with them? If that 73 paper air filter housing is still good someone might want it as a replacement for their oil bath filter. those 2 temp sensors in the plenum work across all d-jet cars and are worth hanging on to. any of that stuff has value to someone looking at converting back to stock from carbs. Not a lot of value given 1.7s are not as popular and there were a lot of them, but for sure not trash. |
Drex |
Mar 14 2023, 07:06 PM
Member Group: Members Posts: 170 Joined: 1-December 22 From: Guthrie Center, Iowa Member No.: 27,003 Region Association: None |
is it possible to weld holes shut in mufflers?
Drex |
Lo-Fi Version | Time is now: 16th June 2024 - 06:41 PM |
