Ignition options, I have issues please help me sort my ignition system |
CCE |
Feb 21 2023, 12:24 AM
CCE Group: Members Posts: 325 Joined: 28-December 21 From: Mexico Member No.: 26,203 Region Association: NineFourteenerVille |
Van B |
Feb 21 2023, 01:01 AM
Senior Member Group: Members Posts: 1,612 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
I put in a pertronix and thought it worked great. I could even see a drift reduction when observing with a timing light.
CCE |
Feb 21 2023, 01:36 AM
I put in a pertronix and thought it worked great. I could even see a drift reduction when observing with a timing light. Cant figure out why is it blowing the coils, my mechanic say it may be a bad production batch, anyone else using the CV kit? Thanks I have. Pertronics distributor here, just need to buy another coil maybe to match. Don’t know wat to do really. |
Superhawk996 |
Feb 21 2023, 07:12 AM
914 Guru Group: Members Posts: 5,876 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Does the coil have an internal ballast resistor? About 4 ohms when you measure the coil primary? No ballast resistor = coil runs too hot and shortens the life.
GregAmy |
Feb 21 2023, 07:17 AM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
What is the "CB Performance ignition kit"? Is it a Pertronix and a coil? If so, maybe just try a Bosch blue coil? There's a lot of folks out here doing that.
Superhawk996 |
Feb 21 2023, 08:10 AM
Hmm - I’d talk to CB Performance. Their coil is low resistance and low impedance. It will pull A LOT of current. A lot more than a Bosch Blue coil. If they designed it for 1 ohm it’s up to them to make sure it can withstand the heat that it will generate.
Not liking 1 ohm primary at all for use with an old school distributor that has long dwell time (time the coil is energized). Low ohm coils like this usually serve only one or maybe two cylinders (in wasted spark application) fuel injection applications. In your application, this coil is trying to serve 4 cylinders. That means the coil is powered with a whole lot more “on” time than whatever application they took this coil from. |
rfinegan |
Feb 21 2023, 08:19 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
Yep, I ATE a LOT of coils on the RX8: lots of sparks 8500-9000 rpm
Hmm - I’d talk to CB Performance. Their coil is low resistance and low impedance. It will pull A LOT of current. A lot more than a Bosch Blue coil. If they designed it for 1 ohm it’s up to them to make sure it can withstand the heat that it will generate. Not liking 1 ohm primary at all for use with an old school distributor that has long dwell time (time the coil is energized). Low ohm coils like this usually serve only one or maybe two cylinders (in wasted spark application) fuel injection applications. In your application, this coil is trying to serve 4 cylinders. That means the coil is powered with a whole lot more “on” time than whatever application they took this coil from. |
76-914 |
Feb 21 2023, 09:33 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Hmm - I’d talk to CB Performance. Their coil is low resistance and low impedance. It will pull A LOT of current. A lot more than a Bosch Blue coil. If they designed it for 1 ohm it’s up to them to make sure it can withstand the heat that it will generate. Not liking 1 ohm primary at all for use with an old school distributor that has long dwell time (time the coil is energized). Low ohm coils like this usually serve only one or maybe two cylinders (in wasted spark application) fuel injection applications. In your application, this coil is trying to serve 4 cylinders. That means the coil is powered with a whole lot more “on” time than whatever application they took this coil from. Good call! You're a regular knowledge bank. (IMG:style_emoticons/default/beerchug.gif) |
rhodyguy |
Feb 21 2023, 12:12 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Is that an Autolite distributor?
CCE |
Feb 22 2023, 11:54 PM
Hmm - I’d talk to CB Performance. Their coil is low resistance and low impedance. It will pull A LOT of current. A lot more than a Bosch Blue coil. If they designed it for 1 ohm it’s up to them to make sure it can withstand the heat that it will generate. Not liking 1 ohm primary at all for use with an old school distributor that has long dwell time (time the coil is energized). Low ohm coils like this usually serve only one or maybe two cylinders (in wasted spark application) fuel injection applications. In your application, this coil is trying to serve 4 cylinders. That means the coil is powered with a whole lot more “on” time than whatever application they took this coil from. Thank you, thank you, thank you! It is strange they sell it as a kit. (IMG:style_emoticons/default/confused24.gif) I will try the pertronix for a while. I have it in hand. |
CCE |
Feb 22 2023, 11:57 PM
CCE |
Feb 23 2023, 12:00 AM
What is the "CB Performance ignition kit"? Is it a Pertronix and a coil? If so, maybe just try a Bosch blue coil? There's a lot of folks out here doing that. Here is a picture, the price was comprehensive. Based on the suggestion I will try the Pertronics distributor and 009 coil I have it on hand (I am running away from points and condensers if possible) |
Superhawk996 |
Feb 23 2023, 05:21 AM
My recommendation would be swap the coil only. Why add more uncertainty by swapping multiple components?
GregAmy |
Feb 23 2023, 06:45 AM
My recommendation would be swap the coil only. Why add more uncertainty by swapping multiple components? Ditto. I'm thinking that disty already has electronic "points". And since your prob is dying coils, I'd suggest just tossing a blue coil on it and see what happens. - GA |
Superhawk996 |
Feb 23 2023, 06:48 AM
My recommendation would be swap the coil only. Why add more uncertainty by swapping multiple components? Ditto. I'm thinking that disty already has electronic "points". It does from what I saw on CB website when I was looking up the coil specs. |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:35 AM |
