Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,737 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
Good morning, hope everyone is having a good (if wet) week.
I've got a throttle linkage issue that I am trying to sort out and looking at PET I noticed there is a different part listed for 914/6 cars vs regular 914s. Specifically the front Reverse Lever (914-423-260-00) is different on 6 cylinder cars and I am wondering if that part needs to be tracked down or if there is a workaround? ![]() |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,376 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
Indeed, the 6 has a different pedal set part (27/1) that the hand throttle rod presses against to raise the RPMs. You might check with Bruce and see if he has one. But, it is not really a complicated part. It is just a tab the rod presses on. One might be able to fabricate that if a stock pedal part were not available. A lot of 6's that were converted to bigger fuel injected engines, removed the hand throttle so there should be some lying around collecting dust. I initially did not reinstall the hand throttle in my car (3.2 with Motronic) but then decided I like having that stock lever where it belonged, so I added it back. @bdstone914 to see if he has one. (IMG:style_emoticons/default/beerchug.gif)
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,008 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
you can convert a car to a 6 without the hand throttle for cold starts/warm ups...
or you will need the part if you intend to have a hand throttle. |
Al Meredith |
Senior Member ![]() ![]() ![]() Group: Members Posts: 973 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 ![]() |
I think Bruce is including that tab on all his rebuilds
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,023 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Tdskip |
Thank you all very much for the fast and (as always) very helpful responses. I appreciate it.
So it looks like that handle throttle related difference isn't impacting my linkage issue, believe it is play in that lever so metal is fatigued or the pedal/bushing assembly is not to spec. @bdstone914 - so you have new/replacement bits on hand if I were to stop by? Thanks! |
Cairo94507 |
@Tdskip - Just a thought, not sure what the condition of your pedal set is, but one of the problems I had when we installed my pedal set was an incorrect clutch pedal arm was installed that was about 5/8" longer on the shaft than a 914 arm. That caused my linkage to sort of stick at certain points- typically when coming off the gas, at a high idle. I reached out to Bruce and he confirmed I had an incorrect part and he sent me the correct part. Problem solved. (IMG:style_emoticons/default/beerchug.gif)
Tdskip |
Thanks @Cairo94507 , appreciate the consideration.
In my case the arm is either bending or flexing and not translating into actual throttle movement. Not sure if the shop just put it together wrong, or if the throttle cable is binding resulting in excessive force at the gas pedal having to be used or maybe cable is too short? Pedal cluster was rebuilt buy a super helpful and competent person here so leaving heavily towards the shop messing it up. I have this vague idea those levers can bend or flex if a weld breaks, might be just confused on that however. Thanks! |
Lo-Fi Version | Time is now: 4th July 2025 - 04:46 PM |
