> help with 914 to 356 transmission swap, flywheel selection
Al Meredith
post Mar 1 2023, 10:22 AM
I am installing a 914 engine into a 356 (a 1973 or 74) I bought the 914 to bug kit from The 914 Store (LN ENGINEERING ) but I have been told the 356 transmission is different and the 356 starter ring may not match. The 200 MM PP may not fit. HELP ! Al
r_towle
post Mar 1 2023, 12:48 PM
Custom Member
QUOTE(Al Meredith @ Mar 1 2023, 11:22 AM) *
I would suggest 356registry.org
If not, pm me and send me your email
I will hook you up to a buddy who knows all about 356, and those you need to ask.
rhodyguy
post Mar 1 2023, 01:18 PM
Jake Raby would know.
Al Meredith
post Mar 1 2023, 04:51 PM
I've already spoken to Jake we plan to get together , he has the parts to show me .
r_towle
post Mar 1 2023, 07:06 PM
Custom Member
Rough answer,
The difference is the starter motor teeth, you may need to convert to 12 volts to make it work.
Rod Emory has one he just did….just seen by a friend, it does work, provided you use the vw flywheel and 12 vdc starter .
Again, rough answer
sixnotfour
post Mar 1 2023, 07:35 PM
QUOTE(r_towle @ Mar 1 2023, 06:06 PM) *
Rough answer,
Again, rough answer
vw use a 914 starter, dont know 356
sixnotfour
post Mar 2 2023, 06:48 PM
and will have to grind bel housing for 12 volt starter ring gear..
- Lo-Fi Version Time is now: 6th July 2025 - 02:15 PM
