| pgollender |
Mar 11 2023, 11:12 AM
Member ![]() ![]() Group: Members Posts: 201 Joined: 5-July 11 From: Sacramento Member No.: 13,281 Region Association: Northern California |
A couple of questions:
What are the 914-4 4 x130 bolt pattern stub axle specs for our cars? Not sure what came with my roller. I measure 93mm O.D. on the outside flange of the stub axle with 36 spline count. I want to keep my rims with the original 4 lug pattern, but am undergoing an engine swap with much more HP and torque. So in reading all the threads with 100mm or 108mm CV's which what the 5 lug hubs guys are talking about, these won't match up with what i have currently. Are these 93mm stub axles not stock? What am I missing here? ![]() |
| 914Sixer |
Mar 11 2023, 03:46 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,529 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
You have stock parts. There is NO upgrade stub axles that will work with the stock 4 bolt pattern. You have to go to 5 bolt 911 type rear hub to get 100mm or 108 CV joints.
| windforfun |
Mar 11 2023, 05:26 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,113 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
(IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif)
Protect those feet!!! |
| pgollender |
Mar 11 2023, 08:04 PM
You have stock parts. There is NO upgrade stub axles that will work with the stock 4 bolt pattern. You have to go to 5 bolt 911 type rear hub to get 100mm or 108 CV joints. (IMG:style_emoticons/default/headbang.gif) Grrr! Taylor Racing may have a 94mm high torque CV + 4 bolt stub axle solution. I've contacted them. Thanks for pointing out my inexperience. |
Lo-Fi Version | Time is now: 3rd August 2026 - 01:39 AM |
