ken914 |
Whole lot 'O 914/6 ![]() ![]() Group: Members Posts: 157 Joined: 15-November 04 From: Mount Pleasant, SC Member No.: 3,122 ![]() |
Can anyone tell me which is the voltage regulator on a 914/6 ????
Thanks!! Attached thumbnail(s) ![]() |
smg914 |
Sahara Beige Steve ![]() ![]() ![]() Group: Members Posts: 1,962 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None ![]() ![]() |
Nothing in the picture is the correct factory stock voltage regulator but if I was to guess, I would say the silver thing screwed into the relay board at the top of the picture is a voltage regulator.
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,912 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
The voltage regulator in picture is for a 4 cylinder. It is a USA made replacement for the Bosch unit. It may work but it may not have the correct output.
ken914 |
Thanks for your help guys!
Overall it is a very very good car, but it has a lot of Dreaded Prior Owner work in it! Some things were done great, some were not... I'm running an '81 SC motor built to 3.2 liters. It is now time to replace the Voltage Regulator, since it has died, any recommendation about what I should put in its place???? |
Maltese Falcon |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None ![]() ![]() |
At some point you may want to consider a later style alternator-- better output and has the regulator built inside of it (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) . You then simply run the B+ red/ Df blu and D- Brn wires directly to the relay board. The 3 wires will go into that same plug you have now.
Marty |
Lo-Fi Version | Time is now: 16th June 2024 - 10:32 PM |
