WTB, Screw Hole Plugs |
silverg |
May 14 2023, 07:59 PM
914s since March 1970 Group: Members Posts: 54 Joined: 7-June 06 From: Winchester, VA Member No.: 6,179 Region Association: MidAtlantic Region |
Need driver door screw hole plugs
bdstone914 |
May 14 2023, 08:04 PM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Which holes? Maybe a picture to show where they go?
silverg |
May 15 2023, 11:24 AM
I believe there are only 2 screw hole plugs on the driver door - the two screws with plugs are near the top ends of the attached door pocket. If one is not familiar with the drivers door, a pic would probably not help. These two plugs are larger than the other couple ‘dozen’ plugs on the car. 914 Rubber nor Pelican seem to carry them.
bdstone914 |
May 15 2023, 01:32 PM
I believe there are only 2 screw hole plugs on the driver door - the two screws with plugs are near the top ends of the attached door pocket. If one is not familiar with the drivers door, a pic would probably not help. These two plugs are larger than the other couple ‘dozen’ plugs on the car. 914 Rubber nor Pelican seem to carry them. I am very familiar with doors but dont know of any plugs. |
Garland |
May 16 2023, 09:17 AM
Restoration Fanatic Group: Members Posts: 1,329 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
The 2 caps/plugs are for the door pocket upper attachment points, they install onto the door pocket. They are larger, like the ones to plug the R & L side of the knee pad.
silverg |
May 16 2023, 10:29 AM
Hey Garland - Thanks for the knee pad reminder…….. those are also missing. Now I need 4! Do you know of a source for new ones? I’ve checked 914Rubber, PP, AA, & Porsche with no luck.
mepstein |
May 16 2023, 10:47 AM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I would start looking at generic plugs at flaps
Lo-Fi Version | Time is now: 7th June 2024 - 10:43 PM |
