914EV Project Mentor updates |
TINKERGINEERING |
May 15 2023, 11:22 PM
Member Group: Members Posts: 182 Joined: 15-March 20 From: Sierra Madre, CA Member No.: 24,031 Region Association: Southern California |
Sorry for my posting issues here...
Just a quick update on where things are at. Mark - @914electric came to visit my progress so far. I have a bit more clarity now that we talked all these project timelines though. Trying to convert and restore a car at the same time makes things tricky. My mission goal #1 is to finish the restoration first. Okay so paint is next, suspension updates, then brake lines and @pmb_performance calipers I helped rebuild with Eric, then wiring harness are on my to-do list! Thanks to Mark for spending the time to help figure this all out! If I can do a little bit every day this will happen. Great Mentors make all the difference. I've met many of the amazing 914 community here. The amount of knowledge and support is great to find here. Receiving help on a project is a good feeling to get. I am beginning to learn that giving advice and helping on others' projects is addicting and might be even more rewarding. Good lessons to start learning. Thanks! Keep on Tinkering! Frances https://www.youtube.com/watch?v=PZQSWvtmA38 |
Chris914n6 |
May 16 2023, 07:13 PM
Jackstands are my life. Group: Members Posts: 3,328 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Typically you paint the outside last. Well technically the windows and trim are last. Too easy to scratch or chip fresh paint while bent over attaching motor stuff or swinging suspension bits around.
You should also pre-fit the custom bits (motor & battery) in case you need to weld brackets or drill holes for the wires etc, before painting the underside/engine bay/trunks. You will also want to fit the rear wheels & tires as you will likely want to roll the fenders a bit, which would suck after paint.... Since you're building the car yourself there really is no 'prefect' timeline. The plan is only to not do things twice or backtrack too often. My timeline is pretty much 1. get everything working 2. take it all apart 3. fix rust & paint 4. put it all back together. |
Lo-Fi Version | Time is now: 3rd June 2024 - 05:08 AM |
