SOLD FS: Steering Wheels OEM |
johnhora |
May 23 2023, 02:02 PM
Senior Member Group: Members Posts: 867 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
ALL ITEMS SOLD
For Sale Two 914 OEM Steering Wheels These are in Good Driver Quality Condition. Not perfect but neither is the price. Part No. 914.347.804.11 For Model 1972 and up....but will fit 70/71 They are both the "Hard Rubber" type...really ebonite Date codes are 12/72 and 7/75 Take your pick... $195 each wheel plus shipping 12/1972 7/1975 more pics below |
johnhora |
May 23 2023, 02:04 PM
johnhora |
May 23 2023, 02:07 PM
johnhora |
May 23 2023, 02:09 PM
Number for reference:
914/4 Model 70/71: 914.347.804.10 for 914/4 Model 70/71 hard rubber 914.347.805.10 for 914/4 Model 70/71 leather 914.347.090.10 for 914/4 Model 70/71 hard rubber w/ horn pad USA only 914.347.091.10 for 914/4 Model 70/71 leather w/ horn pad USA only 914/4 Model 72 onwards: 914.347.804.11 for 914/4 Model 72 onwards hard rubber 914.347.090.11 for 914/4 Model 72 onwards hard rubber w/ horn pad USA only 914.347.805.11 for 914/4 Model 72 onwards leather 914.347.091.11 for 914/4 Model 72 onwards leather w/ horn pad USA only 914.347.809.00 for 914/4 Model 72 onwards foamed ring |
BENBRO02 |
May 24 2023, 07:53 AM
Member Group: Members Posts: 482 Joined: 6-March 15 From: Nokesville, Virginia Member No.: 18,493 Region Association: MidAtlantic Region |
Pm sent
mepstein |
May 24 2023, 09:58 AM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Number for reference: 914/4 Model 70/71: 914.347.804.10 for 914/4 Model 70/71 hard rubber 914.347.805.10 for 914/4 Model 70/71 leather 914.347.090.10 for 914/4 Model 70/71 hard rubber w/ horn pad USA only 914.347.091.10 for 914/4 Model 70/71 leather w/ horn pad USA only 914/4 Model 72 onwards: 914.347.804.11 for 914/4 Model 72 onwards hard rubber 914.347.090.11 for 914/4 Model 72 onwards hard rubber w/ horn pad USA only 914.347.805.11 for 914/4 Model 72 onwards leather 914.347.091.11 for 914/4 Model 72 onwards leather w/ horn pad USA only 914.347.809.00 for 914/4 Model 72 onwards foamed ring There’s also an 803-10 o914-6 hard rubber & 806-10 leather 914-6 both are 1970-71 |
johnhora |
May 24 2023, 10:38 AM
Ben....sent you info
johnhora |
May 24 2023, 10:41 AM
Thanks for the info Mark....I had left those out as these were for 914-4...here's the full version
914 Steering Wheel Numbers 914/6: 914.347.803.10 for 914/6 Model 70/71 hard rubber 914.347.806.10 for 914/6 Model 70/71 leather 914.347.805.11 for 914/6 Model 72 leather 914/4 Model 70/71: 914.347.804.10 for 914/4 Model 70/71 hard rubber 914.347.805.10 for 914/4 Model 70/71 leather 914.347.090.10 for 914/4 Model 70/71 hard rubber w/ horn pad USA only 914.347.091.10 for 914/4 Model 70/71 leather w/ horn pad USA only 914/4 Model 72 onwards: 914.347.804.11 for 914/4 Model 72 onwards hard rubber 914.347.090.11 for 914/4 Model 72 onwards hard rubber w/ horn pad USA only 914.347.805.11 for 914/4 Model 72 onwards leather 914.347.091.11 for 914/4 Model 72 onwards leather w/ horn pad USA only 914.347.809.00 for 914/4 Model 72 onwards foamed ring Any early 914-4 wheel that ends in "10" is identical to a 914-6/early 911 wheel. Besides not having the two little holes drilled to hold the 914-6/911 cancel ring, the wheels that end in "11" have a slightly different chamfer or angle on the back of the aluminum hub where they rest on the steering shaft. The "10" fits a Porsche steering shaft, the "11' fits VW, though you can make either one work. The switchover point between the 10 and 11 wheels started in the 1972 914's. The '72 914-6 used a VW steering shaft and thus used a 914.347.805.11 wheel. |
johnhora |
May 24 2023, 12:19 PM
SOLD...Thanks Ben
mepstein |
May 24 2023, 03:55 PM
Thanks for the info Mark....I had left those out as these were for 914-4...here's the full version 914 Steering Wheel Numbers 914/6: 914.347.803.10 for 914/6 Model 70/71 hard rubber 914.347.806.10 for 914/6 Model 70/71 leather 914.347.805.11 for 914/6 Model 72 leather 914/4 Model 70/71: 914.347.804.10 for 914/4 Model 70/71 hard rubber 914.347.805.10 for 914/4 Model 70/71 leather 914.347.090.10 for 914/4 Model 70/71 hard rubber w/ horn pad USA only 914.347.091.10 for 914/4 Model 70/71 leather w/ horn pad USA only 914/4 Model 72 onwards: 914.347.804.11 for 914/4 Model 72 onwards hard rubber 914.347.090.11 for 914/4 Model 72 onwards hard rubber w/ horn pad USA only 914.347.805.11 for 914/4 Model 72 onwards leather 914.347.091.11 for 914/4 Model 72 onwards leather w/ horn pad USA only 914.347.809.00 for 914/4 Model 72 onwards foamed ring Any early 914-4 wheel that ends in "10" is identical to a 914-6/early 911 wheel. Besides not having the two little holes drilled to hold the 914-6/911 cancel ring, the wheels that end in "11" have a slightly different chamfer or angle on the back of the aluminum hub where they rest on the steering shaft. The "10" fits a Porsche steering shaft, the "11' fits VW, though you can make either one work. The switchover point between the 10 and 11 wheels started in the 1972 914's. The '72 914-6 used a VW steering shaft and thus used a 914.347.805.11 wheel. All correct. Most 911 sites have it wrong. |
Lo-Fi Version | Time is now: 7th June 2024 - 10:39 AM |
