cgnj |
Senior Member ![]() ![]() ![]() Group: Members Posts: 678 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None ![]() ![]() |
Heat exchangers In VGC. Passed smoke test. All welds Intact. Ears Intact. I did notice that the a few of the captive nuts need to be replaced. I have ordered them and will replace all of them.
Triad 2.0 Dual outlet exhaust. I ran these for less than a year and switched to headers. Some cosmetic rust but absolutely solid. 914werks custom hanger Installed and removed. Didn't even take the car off the lift. Stains Steel J Tubes New muffler gaskets $1200/OBO More to come ![]() This case is stamped with GA in the 1.8/1.7 location. Saddles are good, main bearing bore in spec, has not been cut for thrust. 2.0 Rods I did not measure these. I don't use stock rods. But I'm willing to do that. $300 if you pick them up Pertronics 7mm spiral wound ignition wires. Have neve seen an electon. Looked out of place on a MSD distributor $25 +ship Attached image(s) ![]() |
porscheaddic |
Member ![]() ![]() Group: Members Posts: 68 Joined: 9-July 07 From: california Member No.: 7,898 ![]() |
Heat exchangers In VGC. Passed smoke test. All welds Intact. Ears Intact. I did notice that the a few of the captive nuts need to be replaced. I have ordered them and will replace all of them. Triad 2.0 Dual outlet exhaust. I ran these for less than a year and switched to headers. Some cosmetic rust but absolutely solid. 914werks custom hanger Installed and removed. Didn't even take the car off the lift. Stains Steel J Tubes New muffler gaskets $1200/OBO More to come ![]() PM sent |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,323 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
914werke |
If you need restored heater Ducts I have those (IMG:style_emoticons/default/smile.gif)
cgnj |
bump for add ons
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
PM sent
WizPorsche914 |
Member ![]() ![]() Group: Members Posts: 132 Joined: 17-December 07 From: Douglassville PA Member No.: 8,479 Region Association: MidAtlantic Region ![]() |
PM sent
technicalninja |
I've sent 4 pms.
Received a quick response to the first then crickets... I want some of this stuff. Anyone know this member? Is he OK? If something has happened to him, I don't want to be a nuisance. @cgnj are you with us? |
cgnj |
@technicalninja Not going to dignify this with a response.
technicalninja |
I was not trying to insult you.
I did not think my offer was insulting. Your first response showed no heat or displeasure IMO. You wanted my shipping address and offered some other parts. I was expecting a response and more information regarding the other parts. I first checked that I had sent the secondary posts to the right member. I thought I screwed up. Last I heard from you was July 23 at 11 am I do apologize if I stepped on your toes somehow. I wasn't trying to. Rick |
Lo-Fi Version | Time is now: 8th August 2025 - 09:38 AM |
