Dash switch install help |
WizPorsche914 |
Jun 12 2023, 06:32 AM
Member Group: Members Posts: 128 Joined: 17-December 07 From: Douglassville PA Member No.: 8,479 Region Association: MidAtlantic Region |
Hey guys I just replaced my basket weave trim on my 914 and I am having trouble getting the switches back in place, is there a tool or a trick to install the small round metal pieces behind the knobs ? I cannot seem to get them to tread back into the switch behind the dash. Thanks.
ClayPerrine |
Jun 12 2023, 07:05 AM
Life's been good to me so far..... Group: Admin Posts: 15,490 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Hey guys I just replaced my basket weave trim on my 914 and I am having trouble getting the switches back in place, is there a tool or a trick to install the small round metal pieces behind the knobs ? I cannot seem to get them to tread back into the switch behind the dash. Thanks. On everything but the headlight switch, you can use a dime to turn them. Clay |
WizPorsche914 |
Jun 12 2023, 07:32 AM
Hey guys I just replaced my basket weave trim on my 914 and I am having trouble getting the switches back in place, is there a tool or a trick to install the small round metal pieces behind the knobs ? I cannot seem to get them to tread back into the switch behind the dash. Thanks. On everything but the headlight switch, you can use a dime to turn them. Clay What is different on the headlight switch ? |
76-914 |
Jun 12 2023, 08:01 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
The stem sticks out so you need to take a 3/8" washer and cut a slot in it. When reinstalling work left to right.
ClayPerrine |
Jun 12 2023, 09:48 AM
I have an old cheap flathead screwdriver with a 3/8 washer welded to the end, and a slot cut in the washer. The outsides of the washer are ground down so it is not too wide.
Dave_Darling |
Jun 12 2023, 05:58 PM
914 Idiot Group: Members Posts: 14,990 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I have used needle-nose pliers and (large) snap-ring pliers in the holes or grooves in the "escutcheon" (which is what those threaded parts are called in the manual). I've also been able to get them started by hand, then push on the face of the escutcheon while turning it and get them reasonably tight that way. You need to hold the switch to keep it from spinning, though.
--DD |
r_towle |
Jun 12 2023, 06:40 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
mepstein |
Jun 12 2023, 06:55 PM
914-6 GT in waiting Group: Members Posts: 19,300 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
There’s a socket that’s made to install and remove the aluminum piece. Doesn’t cost mych. Worth having in the toolbox.
Garland |
Jun 13 2023, 06:17 AM
Restoration Fanatic Group: Members Posts: 1,329 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
Here you go
Thanks. Ordered. I hate using needle nose pliers. If the part is tight, they slip and scratch it up. |
ClayPerrine |
Jun 13 2023, 07:13 AM
Here you go Thanks. Ordered. I hate using needle nose pliers. If the part is tight, they slip and scratch it up. Group buy? |
ClayPerrine |
Jun 13 2023, 07:42 AM
Here you go Thanks. Ordered. I hate using needle nose pliers. If the part is tight, they slip and scratch it up. Group buy? Well.. so much for that..... Aircooled. net is either out of business or headed that way. |
Steve |
Jun 13 2023, 07:47 AM
914 Guru Group: Members Posts: 5,600 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
https://www.jbugs.com/product/VW012941.html...MRoCRTMQAvD_BwE and its cheaper
dr914@autoatlanta.com |
Jun 13 2023, 10:22 AM
914 Guru Group: Members Posts: 7,875 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
yes they make a tool that looks like a screw driver with a slot in the middle, reaily available
Hey guys I just replaced my basket weave trim on my 914 and I am having trouble getting the switches back in place, is there a tool or a trick to install the small round metal pieces behind the knobs ? I cannot seem to get them to tread back into the switch behind the dash. Thanks. |
barefoot |
Jun 13 2023, 11:03 AM
Senior Member Group: Members Posts: 1,278 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
I cut a slot in a nickel. works fine (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 28th May 2024 - 11:48 PM |
