FS: 901 side shifter with flipped ring and pinion |
AnthonyM |
Jul 15 2023, 11:29 AM
Newbie Group: Members Posts: 38 Joined: 8-December 12 From: Hudson, OH Member No.: 15,243 Region Association: North East States |
A few years ago I purchased a 914-6 project from a 914World member and recently got it running. I quickly found out that someone had flipped the ring and pinion, as I had 5 reverse gears and 1 forward gear. This won't work in a mid engine 914 too well, but it will work in a VW chassis or possibly a 911/912 with some modifications. The transmission comes with the shifter fork and T/O bearing. The engine is not for sale and is back in the 914. Maybe someone here is building a VW or speedster replica? I'm asking $1,300.
Attached image(s) |
Dominic |
Jul 16 2023, 03:41 PM
Dominic Group: Members Posts: 992 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
Anthony,
You can flip the diff in less than an hour...pull the shifter console out and the rear cover off, pull the gear stack out, remove the drive flanges and diff side cover. Flip the diff and re-assemble with new gaskets. Be sure to measure the thickness of the gaskets between the case and the intermediate plate before you replace them. Lots of articles on 914world about the 901 gearbox. Cheers, Dominic |
stownsen914 |
Jul 17 2023, 12:45 PM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
You’d want to check the R&P backlash and potentially adjust the shims on the diff carrier. Not that hard and can be done with non expensive tools. (Not necessary to reset pinion depth, that’s the harder one.)
dug |
Jul 17 2023, 01:59 PM
Member Group: Members Posts: 182 Joined: 26-December 06 From: Santa Cruz, CA Member No.: 7,382 Region Association: Northern California |
All that assumes that whoever put it together flipped had the pinion depth right, but ~might~ totally work.
AnthonyM |
Jul 17 2023, 07:29 PM
Sounds like it may not be such a hassle to put it back into usable condition again? I'll look into this and possibly keep it if that's the case. The shop that I use for some repairs suggested that this would be a very expensive repair. Thanks again for letting me know that this could be a relatively simpler fix than what they were saying.
Lo-Fi Version | Time is now: 1st June 2024 - 03:28 PM |
