Heating system, Can't turn it off |
erwindv |
Jul 26 2023, 06:27 AM
Newbie Group: Members Posts: 46 Joined: 17-June 16 From: Belgium Member No.: 20,119 Region Association: Europe |
Heating in winter is ok but when you can't turn it off in summer it's al little bit too much.
Any idea where to look for the problem? |
DRPHIL914 |
Jul 26 2023, 06:51 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
cable could be too tight so its holding the flappers open, check the tension on those cables that run to each flapper box , i usually remove the tubes and put caps on both ends so no air is flowing from the HE to the tubes up front .
Phil |
r_towle |
Jul 26 2023, 07:02 AM
Custom Member Group: Members Posts: 24,586 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Oddly a normal spray paint can cover fits perfectly on the heater tube end sticking out of the longitudinal, and it keeps out rodents.
Cairo94507 |
Jul 26 2023, 07:05 AM
Michael Group: Members Posts: 9,820 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
It is also possible someone shoved the flappers on more than necessary and the flap is conflicting with the heater tube. That happened to me; I loosed the flapper valve and pulled it back about 1/4" and the flapper opened and closed as it should.
Disconnect the cables to each side at the flapper lever and operate the flapper by hand from under the car to see if it is opening and closing completely. (IMG:style_emoticons/default/beerchug.gif) |
r_towle |
Jul 26 2023, 07:13 AM
Was someone making flapper box rebuild kits?
rhodyguy |
Jul 26 2023, 08:55 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Control wire too tight? Set the operating length with the handle down (fully closed position). The gaskets might be spent or missing.
TheCabinetmaker |
Jul 26 2023, 09:27 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Lo-Fi Version | Time is now: 6th June 2024 - 10:50 AM |
