Engine Install |
Engine Install |
Gordong |
Jul 26 2023, 04:57 PM
Newbie Group: Members Posts: 30 Joined: 20-January 22 From: Carson City Nevada Member No.: 26,268 Region Association: None |
Hello,
I am getting ready to install the engine back in my 75. I have new axles to install. Questions are, should I install the engine without the axles in place? Is there room to put the stub ends and axles in as one with engine and trans in place? Also does the stub ends get packed with grease? Thank you. Gordon |
JeffBowlsby |
Jul 26 2023, 05:13 PM
914 Wiring Harnesses Group: Members Posts: 8,524 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
No on the axles. Engine/Trans assembly as one, then axles. Pack those CV joints with CV grease.
friethmiller |
Jul 26 2023, 05:20 PM
Member Group: Members Posts: 494 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
I installed my axles before installing the engine/transmission. This is doable with a little bit of juggling getting the motor-trans past the axles. I'm not sure about putting the axles in after, like Jeff is recommending. I'm sure he's also correct and is an easier option.
Gordong |
Jul 26 2023, 05:25 PM
Thanks Jeff! My cv joints came packed. When I put the ends on do I fill the cavity with grease?
Shivers |
Jul 26 2023, 05:55 PM
Senior Member Group: Members Posts: 2,408 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Thanks Jeff! My cv joints came packed. When I put the ends on do I fill the cavity with grease? A call to the cv joint manufacturer may let you know if you want to replace the grease now while it is easy. (IMG:style_emoticons/default/smile.gif) |
mlindner |
Jul 27 2023, 04:47 AM
Senior Member Group: Members Posts: 1,525 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Lo-Fi Version | Time is now: 1st June 2024 - 12:31 AM |
