| Front yard mechanic |
Aug 20 2023, 07:02 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,430 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None
My turn signals blink like a sloth S. L. O. W. L. Y. Is it the flash cube or should I just hang my arm out the window
| 914Sixer |
Aug 21 2023, 05:52 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,432 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
I can dig a spare out for you to test with, pay the shipping.
| dr914@autoatlanta.com |
Aug 21 2023, 08:25 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,232 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
| Spoke |
Aug 21 2023, 06:58 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,351 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
EP26 flasher relay is generally available and will light bulbs as well as LEDs just fine. It does need the C2 pin connected inside. It's a straightforward mod if you're handy with a solder iron. If not, I resell EP26 for the 914 with the mod done.
Aug 21 2023, 08:31 PM
| 914Sixer |
Aug 22 2023, 04:50 PM
Went out this morning
Aug 28 2023, 10:17 AM
Thanks Sixer for the flasher cube I replaced it and still no go … so luckily I got one locally and the silver cube next to it that clips in and all it well now. I still don’t know which one was at fault I’m not sure how to bench test these? Also the old silver flasher had 5 prongs and a jumper lead from 30 to 56 but the replacement only has 4 prong. Some day I will need an electrical lesson but my patience is limited
Aug 28 2023, 12:17 PM
You have a high low beam relay on the left and a turn signal relay on the right
Thanks Sixer for the flasher cube I replaced it and still no go … so luckily I got one locally and the silver cube next to it that clips in and all it well now. I still don’t know which one was at fault I’m not sure how to bench test these? Also the old silver flasher had 5 prongs and a jumper lead from 30 to 56 but the replacement only has 4 prong. Some day I will need an electrical lesson but my patience is limited |
Aug 28 2023, 03:02 PM
Nice thx doc
Lo-Fi Version | Time is now: 12th March 2026 - 12:13 PM |
