mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,879 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I’ve decided to sell my Subaru SVX project. I have 99% of the conversion parts to build the car but it needs some metalwork, assembly and finishing. It’s not a bolt together project but it’s not starting from scratch either. As you can read in the build thread, Scott Amenson had started to assemble the car. He did a top end reseal and tuneup on the engine, converted over the transmission to rwd and assembled the suspension. Everything in the parts list is included. The project is probably 95% complete and I will supply as many of the missing parts as I can find, like windows, locks, etc but there will be some parts that are not included, like interior, trim and hardware that the purchaser will need to obtain to complete the car. If you are interested in purchasing, please ask questions on this thread so everyone can benefit from the answer but feel free to PM me for my number. I’m happy to try to explain the project. A lot of my prices are from 2017-2020 but if something looks off, you are welcome to ask. I’d rather sell the project complete but if it doesn’t move in a month or so, I’ll think about breaking it up. If you want to buy the project to flip or part out, that’s fine with me.
The chassis was a California car, brought to NY, then PA. It has a fair amount surface rust where a previous owner stripped off paint and left the metal bare. It has some rust holes on the outer longs. I believe this was due to dirt packed under the rocker panels and not the typical hell hole rust. I don’t believe the longs are rusting from the inside out. There was a roll bar. I cut it out but the welded on pads remain. The installation was not pretty but it is what it is. The front trunk was cut for dealer a/c. I have a good patch panel to weld in. The worst part is definitely the rear trunk. The PO cut out the bulkhead and welded in the big pipe. Scott had carefully prepared a replacement bulkhead from a parts car but it still needs to be fit and welded in. The bulkhead motor mount is designed after a stock 914-6 mount in the way it holds the engine. It gives superior ground clearance compared with an engine cradle as well as unobstructed space to run headers and exhaust. The engine shelf on both sides has been cut away by the PO. This is why I thought the chassis would make a good water cooled conversion. It could be put back to stock with a bit of fab and welding but that’s up to the next owner to decide. Build thread - http://www.914world.com/bbs2/index.php?sho...amp;hl=Smallcar Chassis with steel flairs and good open title. $2,000 5 lug rear suspension - trailing arms with tangerine racing ebrake $500, new wheel bearings $100, 911 SC hubs & stubs ( hubcentric) $400, SC rotors $100, PMB M calipers $300, new Bilstein sport shocks with 160lb springs $400 - $1,700 5 lug front suspension- 3” struts $400, 911 SC hubs ( hubcentric) $300, new bearings $50, SC rotors $100, PMB M calipers $300, 911 19mm torsion bars $200, 911 a arms $100, 911 cross member $100, 911 turbo tie rods $200, 914 front sway bar $300. Bilstein sport strut inserts $300, lemforder ball joints $150 7x15 cookie cutter wheels $400, strut tops & hardware $100 $3,100 Total - $6,800 EG33 Engine - top end reseal, water pump, belts, gaskets, etc, $1,000, small car header $700, custom bulkhead engine mount $500, engine to chassis harness $750, pressure plate and clutch $400. Custom radiator and fan pack $400 $3,750 5mt Impreza trans $400, axles, starter, locking differential sleeve & rear block off plate $400, cable shifter & Suby shifter - $400 - $1,200 Total - $12,150 Sale price for project $8,995 Attached image(s) ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
mepstein |
More
Attached image(s) ![]() ![]() ![]() ![]() ![]() |
mepstein |
More
Attached image(s) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
mepstein |
More
Attached image(s) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
mepstein |
Price reduced to $7,914.
If you are interested in the flared roller with 5 lug suspension but without the engine/trans conversion package, we can talk. I can deliver within 200 miles. I do have a transport guy who will deliver to the east coast and east of the Rockies for a reasonable fee. |
mepstein |
A couple people have asked me about breaking up the project. Here’s what I came up with.
Entire project $7,914 Engine, trans & conversion parts $2,914 Chassis with suspension $4,914 Chassis without suspension $1,914 |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,700 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
I'm thankful that I haven't completed and sold the '76 or I'd be all over this. Whomever buys this is getting a serious discount if they're smart enough to buy the whole enchilada. BTW Mark, that's a MR2 shifter. GLWS. (IMG:style_emoticons/default/beerchug.gif)
SLKWrx |
Member ![]() ![]() Group: Members Posts: 328 Joined: 28-September 04 From: Mickleton, NJ Member No.: 2,845 Region Association: North East States ![]() ![]() |
Hey man,
Would you sell the front and rear suspension all together? |
mepstein |
Hey man, Would you sell the front and rear suspension all together? Only if someone wants the chassis. I lived with it as a chassis on the floor and it’s a pain. Plus, I can use all the suspension parts in another build. However, you are welcome to buy the roller and sell off the chassis. Even with the needed repairs, you already have $1k worth of steel flares and most shops will charge $3-4k to weld them on. The rest of the repairs are an easy diy for an amateur welder. The car is at my shop in Chadds Ford. Looks like you are only ~22 miles away. Just let me know when to drop it off. (IMG:style_emoticons/default/biggrin.gif) |
Chris H. |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,056 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() ![]() |
I'm thankful that I haven't completed and sold the '76 or I'd be all over this. Whomever buys this is getting a serious discount if they're smart enough to buy the whole enchilada. BTW Mark, that's a MR2 shifter. GLWS. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/agree.gif) you're killing me man....if I was closer I'd be interested in the conversion stuff. SOMEONE please buy everything...I'm getting weaker by the day (IMG:style_emoticons/default/beerchug.gif) |
mepstein |
I'm thankful that I haven't completed and sold the '76 or I'd be all over this. Whomever buys this is getting a serious discount if they're smart enough to buy the whole enchilada. BTW Mark, that's a MR2 shifter. GLWS. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/agree.gif) you're killing me man....if I was closer I'd be interested in the conversion stuff. SOMEONE please buy everything...I'm getting weaker by the day (IMG:style_emoticons/default/beerchug.gif) Buy the conversion parts and I’ll New water pump and other parts. |
mepstein |
Bump
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
Sent PM.
Tempting... (IMG:style_emoticons/default/devil.gif) |
76-914 |
Do it Rick. These cars will blow you away with the Subaru 6. That 3.3 is rebuildable if you're thinking long term. And a huge Alt & AC is a plus with these conversions. (IMG:style_emoticons/default/beerchug.gif) |
mepstein |
Do it Rick. These cars will blow you away with the Subaru 6. That 3.3 is rebuildable if you're thinking long term. And a huge Alt & AC is a plus with these conversions. (IMG:style_emoticons/default/beerchug.gif) Rick doesn’t want the Suby parts, just the roller - fine with me. Suby parts are a nice “kit” that will save someone a year chasing down parts and selling at a big discount over retail. Just the headers were $700, oil pan $300, axles, $250, conversion harness $700, cableshift $250, engine mount, etc, etc. |
mepstein |
Entire project, $6,995
ndfrigi |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,965 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California ![]() ![]() |
wow! no takers?
mepstein |
I planned on building a similar looking car to this one without the cut down top. If the market is too soft to sell, I may restart/move forward with the build.
Attached image(s) ![]() |
ndfrigi |
yes sir just finish your plan for this car and enjoy it before selling it on a better price too!
76-914 |
I planned on building a similar looking car to this one without the cut down top. If the market is too soft to sell, I may restart/move forward with the build. I, for one, would love to see you complete this project. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 12th May 2025 - 02:19 AM |
