Oil Tank Hose Removal, Secrets and Tips? |
DennisV |
Sep 17 2023, 04:43 PM
Member Group: Members Posts: 490 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
How does one remove the lower rear oil hose from the tank? I can reach it with my hand inside the fender, but I don't see any way to get a wrench on it that would have enough leverage to remove it. Do you have to take the tank out of the car?
mb911 |
Sep 17 2023, 05:23 PM
914 Guru Group: Members Posts: 6,881 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Typically take it out with the tank.
aturboman |
Sep 17 2023, 05:29 PM
Member Group: Members Posts: 135 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None |
I've had luck coming in from the direction of your RED arrow with a thin line wrench at a 45' angle to the fitting. But it must be clocked right to break it loose or as you say there is no leverage.
ClayPerrine |
Sep 17 2023, 07:24 PM
Life's been good to me so far..... Group: Admin Posts: 15,515 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Typically take it out with the tank. (IMG:style_emoticons/default/agree.gif) I have never found a way to do this with the tank in the car. It is not hard to remove the tank, so just "Yank the tank!" (IMG:style_emoticons/default/biggrin.gif) |
porschetub |
Sep 18 2023, 02:03 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Typically take it out with the tank. (IMG:style_emoticons/default/agree.gif) I have never found a way to do this with the tank in the car. It is not hard to remove the tank, so just "Yank the tank!" (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/agree.gif) I think in the OP's case it won't matter as he will be cleaning his tank anyway,I had mine in and out many times during the conversion , this hose is a bit of a PITA to get in the right position when you do the final fitting. |
Cairo94507 |
Sep 18 2023, 03:52 PM
Michael Group: Members Posts: 9,822 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Pull the tank and then you can deal with the hose. Otherwise it is a nightmare. (IMG:style_emoticons/default/beerchug.gif)
DennisV |
Sep 18 2023, 07:34 PM
It is not hard to remove the tank, so just "Yank the tank!" (IMG:style_emoticons/default/biggrin.gif) Removing the tank wasn't too bad. This thread with the "roll it out" photo was a big help. (IMG:style_emoticons/default/smilie_pokal.gif) Since it's out, what are the recommended inspection and cleaning procedures? Do they get boiled / steam-cleaned like a radiator? Is it made of copper? The outside appears to have been painted black, and in most places gotten the same undercoating treatment as the bottom of the car. The inside seems pretty clean. It is copper colored with some black streaks. It has been indoors and empty for about 20 years. |
Gint |
Sep 18 2023, 08:05 PM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Lo-Fi Version | Time is now: 8th June 2024 - 01:47 PM |
