Hand Throttle Friction Ring, Anyone Have Photos and Dimensions |
DennisV |
Sep 26 2023, 04:31 PM
Member Group: Members Posts: 497 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
Can anyone share a photos and dimensions for the hand throttle friction ring for 914-6 (914-424-219-00)? Ours is missing as astutely pointed out by @bdstone914 . This part is NLA and I've never actually seen one.
What is it made of? If plastic, I will replicate on 3D printer. |
bdstone914 |
Sep 27 2023, 09:16 PM
bdstone914 Group: Members Posts: 4,543 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Can anyone share a photos and dimensions for the hand throttle friction ring for 914-6 (914-424-219-00)? Ours is missing as astutely pointed out by @bdstone914 . This part is NLA and I've never actually seen one. What is it made of? If plastic, I will replicate on 3D printer. It is plastic. You may find an off the shelf bushing. I made a few sets of these and sourced a bushing from Master Carr. You can search by size and see what materials are available. I think the rod is 5.mm. Measure the hole in the bracket for the guide bushing. |
rgalla9146 |
Sep 28 2023, 06:02 AM
Advanced Member Group: Members Posts: 4,570 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Denis I was lucky to find a plastic cap that was a friction fit into the support bracket
I then drilled a hole for the push rod. Sorry, can't provide a source. At the bottom of the page http://www.914world.com/bbs2/index.php?sho...0032&st=220 |
SixerJ |
Oct 1 2023, 02:06 AM
Member Group: Members Posts: 448 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
I think, I have a NOS one in the stash. Need to go and hunt for it
930cabman |
Oct 1 2023, 11:12 AM
Advanced Member Group: Members Posts: 3,183 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I would bet Mc Master Carr has something, Teflon or Delrin
gms |
Oct 2 2023, 08:32 PM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
Mark Bartlett 914 is going to make some this week, put your order in
gms |
Oct 2 2023, 08:43 PM
DennisV |
Oct 4 2023, 03:14 PM
I think, I have a NOS one in the stash. Need to go and hunt for it A couple photos of an original and dimensions would be a great help. If it's for sale, please let me know. Thanks for sharing this Glenn. |
SixerJ |
Oct 5 2023, 12:31 AM
I think, I have a NOS one in the stash. Need to go and hunt for it A couple photos of an original and dimensions would be a great help. If it's for sale, please let me know. Thanks for sharing this Glenn. Hi sorry have been travelling and back at the weekend, as per pics it’s a pretty simple part Will snap some pics and dims of it out of the bracket |
DennisV |
Dec 3 2023, 06:21 PM
To install a new friction ring, you have to remove the plastic cap on the end of the throttle rod. Ours crumbled to pieces. 914-424-225-00 "sleeve" from the diagram. NLA.
I took the opportunity to make one on my 3D printer, based on dimensions from the broken pieces and photos. Printed in in red ABS for my own amusement. You can find it, and my other marginally useful designs, on Thingiverse. P.S. Glenn's friction ring design is pretty clever. |
Mikey914 |
Dec 3 2023, 07:24 PM
The rubber man Group: Members Posts: 12,679 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Just an FYI, for those that have bought our kits, the friction is adjustable in the hand portion of the assembly. Tension is set by pressure on the nut and the large flange plate interacting with the HDPE washer is more than adequate to set and hold.
Adding this part will add friction, but isn’t required for our setup. Feel free to PM me if you need more info. Mark |
930cabman |
Dec 4 2023, 08:26 AM
Just an FYI, for those that have bought our kits, the friction is adjustable in the hand portion of the assembly. Tension is set by pressure on the nut and the large flange plate interacting with the HDPE washer is more than adequate to set and hold. Adding this part will add friction, but isn’t required for our setup. Feel free to PM me if you need more info. Mark I recently installed this kit on a 2056 project with twin Webers, works great. Not sure of the purpose of a "friction bushing"? Is it possible it was not necessary? |
Mikey914 |
Dec 5 2023, 09:19 AM
We built the friction adjustment into the hand assembly. When we assemble we oreliad the friction. These can be adjusted to apply more or less friction by tightening or liisening the nut.
That is why I was pointing out you wouldnt require exter friction devices. |
Lo-Fi Version | Time is now: 17th June 2024 - 06:53 AM |
