solid 215mm clutch disc? |
panayotisnikas |
Oct 10 2023, 05:29 PM
Newbie Group: Members Posts: 25 Joined: 12-March 20 From: Greece Member No.: 24,021 Region Association: None |
Hello everybody, I have the stock 914 clutch on a 2.5lt type 4 and everything is perfect, smooth engagement no slipping , BUT the springs on the disc have gone weak and I am thinking of perhaps a solid disc as its common on type 1 engines , but I can't find a solid 215mm disc, so what are the options here?
Thanks |
mate914 |
Oct 11 2023, 04:59 AM
Matt Group: Members Posts: 757 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
Hello everybody, I have the stock 914 clutch on a 2.5lt type 4 and everything is perfect, smooth engagement no slipping , BUT the springs on the disc have gone weak and I am thinking of perhaps a solid disc as its common on type 1 engines , but I can't find a solid 215mm disc, so what are the options here? Thanks I think you can get a four or a six spring clutch disk. Original was rubber and no springs, the 914-6 had a six spring disk. Try that one. Matt (IMG:style_emoticons/default/flag.gif) |
914Sixer |
Oct 11 2023, 05:57 AM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Maybe weak fingers on pressure plate
Attached image(s) |
brant |
Oct 11 2023, 06:04 AM
914 Wizard Group: Members Posts: 11,638 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I don’t remember any rubber on the clutch of a 914
That was mid 80’s 911s/944s Not on the 914 |
stownsen914 |
Oct 11 2023, 06:14 AM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
What symptoms suggest that the springs on the disk are weak?
For anything other than racing use, I'd recommend against a solid/unsprung disk. Clutch engagement with a solid disk is very harsh. The shaking and shuddering will drive you crazy on a street driven vehicle. Hard on the driveline too. |
mate914 |
Oct 11 2023, 01:21 PM
Lo-Fi Version | Time is now: 7th June 2024 - 08:02 AM |
