AFR vs MPG |
AFR vs MPG |
Geezer914 |
Nov 9 2023, 01:19 PM
Geezer914 Group: Members Posts: 1,433 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
VaccaRabite |
Nov 9 2023, 01:22 PM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Thats about what I used to see as well.
I'm sure it could be tuned for more economy at the expense of power. Zach |
930cabman |
Nov 9 2023, 03:07 PM
Advanced Member Group: Members Posts: 3,130 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Running a 2056 with 1.8L L-Jet fuel injection. AFR is set at 13.1. MPG is around 20 miles per gallon. Plugs are a little dark but not fouled. Does this sound right? Is this in town MPG? My 2056 with twin 40 IDF's gets a bit over 30MPG at 75MPH highway. No idea what the AFR is, plugs look ok. Funny I have a new LM-2 in the box, can't figure out how to get it going |
StarBear |
Nov 9 2023, 03:27 PM
Senior Member Group: Members Posts: 1,906 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Thats about what I used to see as well. I'm sure it could be tuned for more economy at the expense of power. Zach (IMG:style_emoticons/default/agree.gif) At idle On standard 1.8 FI. Planning on changing our nearly original injectors and checking/adjusting valves (many years overdue) to lean a bit further (running 10.0-12.0) at rpm. Might tweak the AFM a bit more but pretty near point where it hasn’t helped. |
emerygt350 |
Nov 9 2023, 06:22 PM
Advanced Member Group: Members Posts: 2,132 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
That plug looks nice to me. Where is your o2 sensor?
I get almost 20 in town and 28ish on the highway but I drive like gas doesn't matter in town. I can't help it ... Maybe 270 miles on 13 gallons (I don't trust my fuel gauge yet so I always fill up as it drops below 1/4 tank). On my 2056 djet I am at 14.2ish cruising and between 11-12 on WOT. My O2 is right after the 3 and 4 combine in my ansa (before the muffler). |
Geezer914 |
Nov 9 2023, 07:47 PM
My 02 sensor is in my Triad muffler.
Krieger |
Nov 9 2023, 11:38 PM
Advanced Member Group: Members Posts: 4,723 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Looks good. I wouldn't go any leaner.
930cabman |
Nov 10 2023, 06:20 AM
Porschef |
Nov 10 2023, 03:44 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Running a 2056 with 1.8L L-Jet fuel injection. AFR is set at 13.1. MPG is around 20 miles per gallon. Does this look right? Interesting, I’m running the same setup. Also right around that AFR# and very similar mileage numbers. I always thought it would be a little better but I’m willing to sacrifice mpg’s for engine longevity. It’s not a DD so I live with it (IMG:style_emoticons/default/beerchug.gif) |
Geezer914 |
Nov 10 2023, 04:17 PM
Sacrificing some mpg for performance. 20mpg and it's a blast to drive, I can't complain.
Chris914n6 |
Nov 10 2023, 06:09 PM
Jackstands are my life. Group: Members Posts: 3,328 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Could be better. A stock 2.0FI is like 25-30. My 3.0FI was 24-29 mpg @ 90 mph.
Geezer914 |
Nov 10 2023, 06:33 PM
I am running Len Hoffman RS heads with larger valves and a 50 mm throttle body, so not as efficient as a stock 2.0.
emerygt350 |
Nov 10 2023, 07:34 PM
I mean, theoretically... You are moving the same weight so it shouldn't take more fuel unless you are driving it inefficiently. I know I am. Just try and miser your 2056 around. I just can't do it. I am always reaching into the throttle....
Geezer914 |
Nov 10 2023, 08:04 PM
I try to keep the RPMs above 3K as much as possible.
emerygt350 |
Nov 10 2023, 08:07 PM
Exactly
Chris914n6 |
Nov 10 2023, 09:43 PM
I am running Len Hoffman RS heads with larger valves and a 50 mm throttle body, so not as efficient as a stock 2.0. Air + gas = HP. I've got 190 hp & 205 tq and get 24 mpg around town. Granted I don't have to push as hard to be fast, but it's still a formula that is consistent. A non-track car doesn't need the cooling effect of running that rich. |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:25 AM |
