New 914-4 rear brake pads? |
Tom1394racing |
Nov 15 2023, 02:12 PM
Member Group: Members Posts: 297 Joined: 25-August 07 From: CT Member No.: 8,039 Region Association: North East States |
What rear pads should I use that will fit the thick top caliper retaining pin? All the pads I see that match the 914-352-923-01 P/N seem to show the small lug hole on the pads. I would like to avoid having to enlarge the top hole on the pads.
Shivers |
Nov 15 2023, 03:24 PM
Senior Member Group: Members Posts: 2,433 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I’d call Eric at PMB. If anyone can… Link : https://pmbperformance.com/
brant |
Nov 15 2023, 03:39 PM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I’d just buy the good street pads (r4s?) over stock pads even if you have to enlarge the hole
914Sixer |
Nov 15 2023, 03:50 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
99% of the time you have to drill out rear pads to fit pin.
Tom1394racing |
Nov 15 2023, 03:58 PM
fixer34 |
Nov 15 2023, 05:09 PM
Senior Member Group: Members Posts: 1,092 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
99% of the time you have to drill out rear pads to fit pin. Thanks Guys...That is what I will do. Yep, that's what I've had to do over the years. Just remember to drill out two 'lefts' and two 'rights' as you look at the pads face up. |
bkrantz |
Nov 15 2023, 07:28 PM
914 Guru Group: Members Posts: 7,804 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
What do you have on the front? I would not want mine to be too different.
Tom1394racing |
Nov 15 2023, 08:01 PM
mskala |
Nov 16 2023, 05:14 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
The 914-6 rear pads are the same size as the 914-4 front pads (early I think? instead of late).
So, you can either find 2 more small pins (1 for each side) or just turn down the ones you have in a lathe. Back in the day I bought the PMB Aluminum copy of the 914-6 rear calipers and made some aluminum pins (to save weight (IMG:style_emoticons/default/biggrin.gif) ) (All thin pins to fit the standard holes) Mark S. |
Tom1394racing |
Nov 17 2023, 09:01 AM
The 914-6 rear pads are the same size as the 914-4 front pads (early I think? instead of late). So, you can either find 2 more small pins (1 for each side) or just turn down the ones you have in a lathe. Back in the day I bought the PMB Aluminum copy of the 914-6 rear calipers and made some aluminum pins (to save weight (IMG:style_emoticons/default/biggrin.gif) ) (All thin pins to fit the standard holes) Mark S. Thanks Mark I have several NOS sets of SWB 911 pads. I took one set and drilled out the holes with my drill press. Seemed easy enough and fit well. However, my rebuilt calipers from PMB came without the inner adjusters. I am waiting for a set from them. |
Lo-Fi Version | Time is now: 10th June 2024 - 01:27 PM |
