East coaster |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,866 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None ![]() ![]() |
Has anyone successfully clocked their wiper arms (by repositioning the arm on the motor) while the fresh air box was still installed? I could kick myself for not checking this before installing my wiper assembly and airbox, but my wiper are parking almost straight up…..ugh!
I’m really not looking forward to removing my freshly installed airbox. |
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,466 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
Yes.
Do your wipers swing in a full arc? If they swing too far and hit the cowl, then turn the wiper arms up to be parallel to the pivots. If you confirm that, then remount the arms to park in the right location. |
East coaster |
I don’t have a windshield or wiper arms/blades installed yet, but I can see that the wiper shafts rotate fine clockwise and counterclockwise but they park (shafts stop rotating) in mid arc (which would be about straight up if the arms/blades were on.
I’m just trying to figure out if it’s even possible to get to the 10mm nut on the wiper motor shaft to re-clock the arm with the airbox installed. |
pek771 |
Member ![]() ![]() Group: Members Posts: 275 Joined: 23-November 05 From: Conover, NC Member No.: 5,175 Region Association: None ![]() ![]() |
A bit ot, but which wire is for parking the wiper arms?
mgarrison |
Member ![]() ![]() Group: Members Posts: 398 Joined: 14-February 20 From: Chandler, AZ Member No.: 23,922 Region Association: Southwest Region ![]() ![]() |
A bit ot, but which wire is for parking the wiper arms? I could really use the answer to this question as well! #53 = slow speed #53B = fast speed #53A = UNKNOWN #31B = UNKNOWN Hoping the 914 World Gurus have an answer... (IMG:style_emoticons/default/pray.gif) |
East coaster |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,786 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Loosening the 10mm and short arm is easy. Getting a wrench in there and tightening it in the new position, that's tough. Depends on patience and dexterity. DO NOT put the wiper arms on until you are certain where they will park |
Lo-Fi Version | Time is now: 31st July 2025 - 08:01 AM |
