Targa seal installation video is up, Bulkhead, trunks, window scraper and body too |
iankarr |
Jan 20 2024, 12:19 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,481 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hey Guys,
I just posted a video on installing a bunch of seals, including the targa. Hope this helps demystify the process and keep you dry. Enjoy! https://www.youtube.com/watch?v=FCbuWuLjB3U |
76-914 |
Jan 20 2024, 01:13 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Great video Ian. If the windshield is out, using the zip ties makes the job so much easier. You'll need the tool to tighten the zip ties correctly. I noticed you had a gap in the curved area of the A pillar right around the 8:44 mark. Did you correct that yet? If not try using the zip ties. After 3 failed attempts to snug that seal in the curved area I stumbled upon using zip ties.
iankarr |
Jan 20 2024, 01:19 PM
Very cool idea Kent! The curve on my install relaxed after a few weeks and looks good now. I probably should've mentioned that in the video. Also, the characteristics of repo seals aren't quite the same as OEM. The fact that the tab needs to be trimmed is a case in point. I assume that the new seals are slightly stiffer, which also keeps the curve flatter...requiring zip ties or time.
Lo-Fi Version | Time is now: 8th June 2024 - 06:13 PM |
