Parking brake, Adjustment trouble and more |
NARP74 |
Mar 17 2024, 10:41 AM
Senior Member Group: Members Posts: 1,073 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I am following the Haynes adjustment procedure and can't get it right. One side grabs too much and the other is way off. The two cables are not level in the yoke at the handle end. Had a big fight with rust on the right side cable adjuster end. That side is the problem getting it adjusted too for some reason, probably unrelated.
Guess I will undo everything and start over. Any tips or tricks? |
burlybryan |
Mar 17 2024, 04:06 PM
Member Group: Members Posts: 106 Joined: 25-May 20 From: Saint Paul Member No.: 24,311 Region Association: None |
My experience.
http://www.914world.com/bbs2/index.php?sho...=367149&hl= I had struggled with the yoke being skewed one way as well, but finally figured it out. Hopefully this helps. |
NARP74 |
Mar 19 2024, 08:06 AM
I did find one issue, the PO had zip tied the left side cable housing up to keep it off the headers. That would not allow it to move and take up the slack. It also increased the fulcrum effect of the yoke and adjustments to the right side. I'll start over now and hopefully sneak up on the proper adjustment.
NARP74 |
Apr 2 2024, 04:44 PM
So what temp do the headers get to? I need to buy some heat shielding since my parking brake cable is now sitting directly on the MSDS header. I'll see if I can route or fix it somewhere, but the last approach stopped it from being adjustable.
Lo-Fi Version | Time is now: 7th June 2024 - 11:05 AM |
