gear selector rod installation (not in neutral anymore) |
cause |
Apr 21 2024, 05:48 PM
Newbie Group: Members Posts: 39 Joined: 6-May 21 From: new york Member No.: 25,514 Region Association: None |
was following the guide below and trying to get the gear selector back in the transmission—unfortunately I am no longer in neutral and the guide only says "get more difficult"... I'm hoping someone can help describe what needs to happen as the diagrams aren't helpful and I am doing this in the dirt and under jackstands (read: I am losing my mind)
TIA! https://www.pelicanparts.com/techarticles/9...select_seal.htm |
Superhawk996 |
Apr 22 2024, 06:41 AM
914 Guru Group: Members Posts: 5,898 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Use long screwdriver or similar tool to realign the internal shift forks to neutral position that allows the console to slide in.
A picture of what you’re dealing with and where your shift forks moved to is worth 1000 words. Internal shift rods should align along green line so gear selector console can slide in |
cause |
Apr 22 2024, 12:40 PM
Thank you thank you thank you!
Was able to get it all back together |
Lo-Fi Version | Time is now: 8th June 2024 - 05:56 PM |
