bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
1: Is it unheard of to have a stretched-out advance spring, so when the mechanical advance is full-out, the weights contact the case? I think this is the rattle metal sound I hear.
2: I have Falken ZE-502 tires...they recommend a 44PSI pressure when cold, but the sidewall sways..... can i run a higher pressure, and what is that recommendation? |
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
Hey Beavis.... (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) I still have those two dizzys sitting on the shelf. Sent the serial number(s) awhile back.
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
In order to get get maximum advance having the counter wieghts hitting the the inside edges of the body is a good thing. (more advance.
Sure you can put more air in your tires just set the automatic shut off a little higher. Gas mileage will increase you will go faster with less rolling resistance (IMG:http://www.914world.com/bbs2/html/emoticons/spank.gif) |
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
There are usually stops in place to prevent the weights from moving "too far".
Useful tire pressure is related (among many other factors) to load. A 3000lb car with four fat people in it will require a higher pressure than a 2000lb car with one beanpole driving. The pressure on the sidewall is pressure for maximum rated load. 44psi sounds very high to me, but I've not used Falkens, so I can't say if that's too high. |
bd1308 |
(IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) Beavis....
okay, lemme dig through my pm's.... i was just wondering if this could happen... |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
for the dizzy...not sure, just pop the cap off and see if you can swing them out to hit the case....
I wouldn't fool around with the tire pressure....there is a reason it's recommended...too much and "boom" (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
bd1308 |
okay
and figured so |
Joe Ricard |
Do you sit around and Really think this shit up? just to "post whore" the board.
With that many posts you should have a running car that is concourse prefect and winning races. Then fall back on the no money honey sob story? I'm sure someday you will graduate college and make bucket loads of money more than me. But you know there have been SOO MANY people here who try and help you. Geez dude. Ok I'm done and yes my chain is tired of being yanked. |
Rouser |
Anti-Post Whore ![]() ![]() ![]() Group: Benefactors Posts: 597 Joined: 30-December 02 From: Citrus Park, Florida Member No.: 54 ![]() ![]() |
1: OK, I've never heard of that happening (the weights are limited as to how far they'll swing), but you're starting to prove that ANYTHING'S possible. My opinion is I would search elsewhere.
2: 44 PSI?! Woah, your car must ride like crap, loosening your fillings and darting about on every seam and cockroach you run over! And you wanna go higher? Sidewalls are gonna flex some (they'd better, with your '70's suspension), unless you're going for a nostalgic Schwinn ride. If you think it's the distributor, get a rebuilt unit. Try 26-27 PSI all around and see how it handles, unless your Dad's a dentist. |
bd1308 |
my dad is a oral surgeon actually.
joe i'm not yanking NOTHING of yours... alright, i'm out. i had enough. |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
improper grammar - im not yanking *anything* of yours - would be correct. |
bd1308 |
then you can fix it, admin
Lo-Fi Version | Time is now: 16th July 2025 - 04:02 PM |
