> Help - Need 50mm cooling ducting, Black Plastic
Cairo94507
post Jun 10 2024, 12:05 PM
Michael
We are having an issue finding 50mm ducting (hose) to go from the "mouse ears" to the heater flapper. What we have is the rather inexpensive cardboard tubing available pretty readily. I am looking for something that is almost a plastic coated duct hose that would withstand dirt and possible....getting wet, and be able to keep clean. We have some in 60mm that is the finish we want, it's just too big.
We have searched high and low and came up scratch. I did find some 50mm plastic hose in the UK, but it only comes in 300mm/30cm (11.81 inches) lengths. I really need something that is 30 inches, 76.2cm or 762mm.
Anyone have a suggestion?
Thanks all,
Michael (IMG:style_emoticons/default/beerchug.gif)
56kabrio
post Jun 10 2024, 12:20 PM
QUOTE(Cairo94507 @ Jun 10 2024, 02:05 PM) *
Thanks all,
Michael
Found this ad in the UK. Sold in 23 meter roll.
https://www.autosiliconehoses.com/pvc-corru...m-23-metre.html
Hope this helps.
Mack
burton73
post Jun 10 2024, 12:23 PM
Senior member, and old dude
@Cairo94507
50 MM is 1.9685 inch very close to 2 inch. Aeroduct Ducting
www.wicksaircraft.com
Take a look. You are very close to getting this.
Best Bob B
Cairo94507
post Jun 10 2024, 12:37 PM
Michael
Hi Bob & Mack,
It looks like Bob's referral is available in the length I need for a not ridiculous price. I just need to verify with Greg that that will work. But, it does look like what we need.
Cheers,
technicalninja
post Jun 10 2024, 01:08 PM
Mack's hose is rated to 55c or 131F. Not high enough IMO for the application.
Running would work fine due to the cooling air but shutdown "heat soak" might hurt it.
Bob's suggestion is a mere 1/32 of an inch too BIG. I didn't check heat rating on it (you should) but if a "tiny bit too big" won't work I'd be surprised.
JeffBowlsby
post Jun 10 2024, 01:16 PM
Seems to me there was a NAPA hose that was nearly identical to stock. I don't recall more than that.
930cabman
post Jun 10 2024, 01:43 PM
QUOTE(JeffBowlsby @ Jun 10 2024, 01:16 PM) *
I used the NAPA hose recently and it worked perfect. I will look around later and see if I can find anything. A search for this took me quite a while, and I might have saved the tag, somewhere. It took the guys at NAPA awhile to find it in their system, might be called "defroster hose"
RAX914
post Jun 10 2024, 02:37 PM
Aircraftspruce.com:
https://www.aircraftspruce.com/catalog/appa...?clickkey=77121
They also have it in black
slowrodent
post Jun 10 2024, 03:24 PM
Bunch on eBay right now as 2” defroster hose. Just saying
Montreal914
post Jun 10 2024, 03:53 PM
Isn’t that aero ducting too stiff? Seems like every time I see it used it bends only on one spot instead of making a nice natural bend along the whole way. (IMG:style_emoticons/default/confused24.gif)
Cairo94507
post Jun 11 2024, 07:13 AM
Michael
Thanks to all who helped move this ball down the field. I now have several options and the next time Greg and I meet, maybe tomorrow, we can discuss them and see which way we go. For now though, we can use the 50mm cardboard stuff as it will be easy to swap once the motor is in the car. (IMG:style_emoticons/default/beerchug.gif)
technicalninja
post Jun 11 2024, 07:57 AM
I've never seen the cardboard stuff fail due to heat.
It can get old and delaminate, but heat doesn't seem to mess with it.
mb911
post Jun 11 2024, 08:27 AM
Wag aero group sells it. I bought some off Amazon it’s labeled sceet or scat tubing.
Luke M
post Jun 11 2024, 08:33 AM
https://www.amazon.com/AC-PERFORMANCE-Autom...sr=8-1&th=1
Check this out..
technicalninja
post Jun 11 2024, 09:23 AM
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif)
Yes, check that OUT!
I know what I'd use.
572F working temp!
Water resistant! (I was going to mention the cardboard stuff probably shouldn't get wet)
Got a "German" look to it...
But the absolute most "KILLER" thing about is the inner sheath...
This is a BIG problem with brake ducting hoses. The ones with the corrugated inners decrease flow BIGTIME! A 2" hose is the equivalent of a 1.5" with the ribbed inner surface.
That has a nice sleeve!
I know what I'll use from now on for brakes duct hosing!
Reasonably priced as well.
@Luke M (ok how can I tag "Luke M")
You kick ass Sir!
Thanks for that link
NARP74
post Jun 11 2024, 09:26 AM
@Luke M quotes around the user name with spaces etc.
Luke M
post Jun 11 2024, 09:32 AM
QUOTE(technicalninja @ Jun 11 2024, 08:23 AM) *
572F working temp!
You kick ass Sir!
Glad to help out. I'm laid up for a bit til I get an MRI done and see the Dr. so shopping online is what I'm doing.. (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/type.gif)
Cairo94507
post Jun 11 2024, 03:33 PM
Michael
@Luke M - Thanks for that link. I think that may be the winner. I will talk with Greg tomorrow when we get together and if that passes his review, that is what I will order. Thanks a lot for the help everyone. It takes a freakin' village for sure. (IMG:style_emoticons/default/beerchug.gif)
- Lo-Fi Version Time is now: 15th July 2025 - 03:52 AM
