> Bulkhead engine acess panel?
SKL1
post Sep 11 2024, 01:59 PM
In the process of repainting my '71 and adding the bulkhead 6 engine mount. While the car is all apart I remember seeing someone do an access panel in the bulkhead for "emergency" engine access.
Does anyone have pictures of such a modification? TIA.
Montreal914
post Sep 11 2024, 02:32 PM
Recently been looking at this. Here is a thread with a few of them shown. One way is to use an extra firewall sheetmetal to make a nice form fitted panel. (IMG:style_emoticons/default/smile.gif)
http://www.914world.com/bbs2/index.php?showtopic=369381
Garland
post Sep 11 2024, 02:36 PM
Restoration Fanatic
@SKL1
Here’s the topic
2008
Access door
Steve
post Sep 11 2024, 04:39 PM
With the right tools, you can easily change the fan belt, without cutting the firewall. I finally cut a hole when it was time to change the alternator. I did not want to drop the motor. I used PMS's fiberglass cover. https://patrickmotorsports.com/products/bod...K9wRboJZifp87C7
Cairo94507
post Sep 13 2024, 06:03 AM
Michael
On my 2nd 6, back in the mid-80's, we did an access panel when we swapped in a 3,0. I got a section of firewall from a wrecked 914 and we used riv-nuts in the firewall with a nice weatherstrip around the hole and overlapped the new panel about 1" all the way around. Painted to match and it sealed really nice and I never could detect any louder engine noise as a result. (IMG:style_emoticons/default/beerchug.gif)
930cabman
post Sep 13 2024, 12:00 PM
QUOTE(Cairo94507 @ Sep 13 2024, 06:03 AM) *
Is your current /6 (3.6 monster by the way) your 3rd, 4th, ...
Some guys are very fussy with cutting the firewall, I cut mine and sealed it up. If a fire burns long enough to get through, we will be having other problems for sure
post Sep 13 2024, 12:38 PM
Resident German
Just remember, it's called a FIRE-Wall for a reason.
Don't use any flammable materials, not even for the sealing/gasket. It can make all the difference between having 30 seconds to get out of the car and burning alive.
(IMG:style_emoticons/default/unsure.gif)
930cabman
post Sep 13 2024, 01:05 PM
QUOTE(SirAndy @ Sep 13 2024, 12:38 PM) *
Make it tight fitting like the post #3, you will be fine. It's easy to change the belt, check timing, not so good for removing the alternator
914werke
post Sep 13 2024, 01:34 PM
If someone is interested I have a cut panel section that been kicking around too long (IMG:style_emoticons/default/rolleyes.gif)
post Sep 13 2024, 03:42 PM
QUOTE(SirAndy @ Sep 13 2024, 02:38 PM) *
(IMG:style_emoticons/default/agree.gif) NEVER cut a hole in the FIREWALL (IMG:style_emoticons/default/chair.gif)
worn
post Sep 13 2024, 06:21 PM
QUOTE(73-914 @ Sep 13 2024, 02:42 PM) *
It is an issue but then Porsche designed in a pretty direct hole from the fuel tank and into the cabin. I have one. Made from a wrecked salvaged panel with a big overlap and lots of fasteners that are real bolts and nuts (welded).
Cairo94507
post Sep 14 2024, 06:54 AM
Michael
My current 6 (Irish Green) is my 3rd 6 and 4th 914; I am a mere newb compared to some. (IMG:style_emoticons/default/beerchug.gif)
ClayPerrine
post Sep 14 2024, 10:13 AM
QUOTE(73-914 @ Sep 13 2024, 03:42 PM) *
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif)
I have lived an engine fire. I will do anything to prevent another one, and if it does happen, anything to slow it down.
NEVER CUT A HOLE IN SOMETHING CALLED A FIREWALL. It's the equivalent to cutting a hole in a parachute so you can see the sky better.
post Sep 14 2024, 10:48 AM
914-6 GT in waiting
Well sure, you are cutting a hole but then you are covering it up. Most 914 & 911 fires seem to be caused by old fuel lines. I’m betting that the guys cutting access panels for their six’s have modernized their fuel delivery.
ClayPerrine
post Sep 14 2024, 07:15 PM
QUOTE(mepstein @ Sep 14 2024, 10:48 AM) *
We have stainless steel lines in all these of our 914s. And I still will not cut a hole in a firewall. An intact firewall may make the difference between getting out of the car injury and some really awful burns.
worn
post Sep 14 2024, 09:28 PM
QUOTE(ClayPerrine @ Sep 14 2024, 06:15 PM) *
I think that you make a good argument.
As a lifelong scientist, I am curious. One thing that I would like to know would be the level of firewall distortion that might be expected in a very bad but survivable impact. From any direction. One would want to see the worst damage and thus seal loss that might be expected. Another factor would be how often the back window might fail in such an accident, as fire in the engine compartment would travel through that space as well if it existed. I am driving a ‘72, with less protection than offered my ‘76. It is of some concern too.
930cabman
post Sep 15 2024, 06:20 AM
Having the steel firewall is great, but having the rear glass at your head level with ordinary (tempered) glass is a problem. The rear glass will fail much sooner than a smallish access panel in the firewall.
I cut an access panel when I did my recent /6 conversion and made sure it is sealed.
mlindner
post Sep 15 2024, 07:51 AM
I installed an acèss panel, love it, sealed. Great for timing/valve adjustment. Best, MarkAttached Image Attached Image
- Lo-Fi Version Time is now: 2nd April 2026 - 11:59 AM
