| Geezer914 |
Oct 4 2024, 06:44 AM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,383 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
75 914. When the emergency brake is on, the red light flashes on the fuel gauge and the blinker light on the tachometer??? Relay going bad?
| 87m491 |
Oct 4 2024, 08:20 AM
Member ![]() ![]() Group: Members Posts: 332 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States
| dtmehall |
Oct 4 2024, 07:26 PM
Member ![]() ![]() Group: Members Posts: 402 Joined: 21-December 23 From: Michigan Member No.: 27,808 Region Association: Upper MidWest |
no, only the fuel gauge light should blink.
have you done any work behind the dash or any other lights recently? |
| Geezer914 |
Oct 5 2024, 01:43 AM
No, do they flash off the same relay?
| Spoke |
Oct 5 2024, 06:52 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,438 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
no, only the fuel gauge light should blink. (IMG:style_emoticons/default/agree.gif) The MC brake / Ebrake warning light is the only light that should blink if the OEM flasher is installed. If the flasher is EP26 LED-compatible flasher then both will flash together. Attached thumbnail(s) |
| davep |
Oct 5 2024, 03:16 PM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,382 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
| Geezer914 |
Oct 5 2024, 05:29 PM
no, only the fuel gauge light should blink. (IMG:style_emoticons/default/agree.gif) The MC brake / Ebrake warning light is the only light that should blink if the OEM flasher is installed. If the flasher is EP26 LED-compatible flasher then both will flash together. Jerry, now that you mention it my flasher is an EP26. I remembered I installed it when I converted all my lights to LED's. It's a sucks getting old! |
Lo-Fi Version | Time is now: 15th November 2026 - 09:46 PM |
