> 986 Boxster cable, cable end removal
Steve1956
post Jan 28 2025, 01:00 PM
Hi guys,is it possible to remove these cable ends? I want to replace them with heim joints.Attached Image
ClayPerrine
post Jan 28 2025, 03:27 PM
QUOTE(Steve1956 @ Jan 28 2025, 01:00 PM) *
I looked at this when I went to the Cayman 6 speed. You can't remove the ends. They are crimped onto the cable.
I used Numeric shift cables.
https://numericracing.com/products/performa...-cables-986-987
They are not cheap, but they use really nice joints on the ends of the cables, and they are removable.
ClayPerrine
post Jan 28 2025, 03:32 PM
Another thing... on my car, I ran them through the speedo cable and shift rod openings on the firewall. But to do it, I had to turn the flanges down on the shifter end of the cables.
That involved fitting a long piece of pipe to the back of the lathe to support the cables, and spinning the lathe VERY slowly while removing the flange.
Then once they were through and in the car, I just put another nut on the cable to anchor it to the shifter.
Steve1956
post Jan 29 2025, 01:00 PM
What I thought I would try if the rod is soft enough,cut the end off and thread it with a die. They are 6mm in diameter.
Whoa!,,,I guess they are pricey! Yeah,gonna try threading them!
914_teener
post Jan 29 2025, 05:44 PM
+1 on the Numeric cables. Shifts like silk.
worn
post Jan 29 2025, 09:50 PM
QUOTE(ClayPerrine @ Jan 28 2025, 01:32 PM) *
Da man. You can visualize skill in getting the spin just right.
- Lo-Fi Version Time is now: 26th September 2025 - 06:06 AM
