Shift rod adjustment, if U had to figure it out from scratch.. |
Dr. Roger |
Aug 30 2005, 12:11 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
I chopped my shift rod because i wanted to straighten it for the V8 conv. And other reasons....
I'm thinking i would just put the tranny in reverse and then put the shifter in the reverse position and weld the shift rod where the two pieces meet. Can anyone with some experience see any flaws in this thinking? Is there anything I should watch for? Besides flying monkeys coming out my butt? (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Miles... |
Aaron Cox |
Aug 30 2005, 12:19 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
2nd or third is a little easier. no side to side tension. put the trans in 2nd and the shifter straight up. make sure you have some adjustment room at the shifter connection (splined rod meets the clamp at the shifter) make sure BOTH cone screws are tight..... should work |
lapuwali |
Aug 30 2005, 12:30 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
I'd not use reverse, as you have (or should have) spring tension on the shifter in that position. I'd use 2nd or 3rd. It doesn't matter all that much, as you have lots of leeway at the adjuster to get it aligned after you've welded the two pieces together. In fact, I'd consider doing a partial alignment, mark the two pieces, and remove them from the car so you can weld them on a bench so have a better chance of getting them straight.
Dr. Roger |
Aug 30 2005, 12:48 PM
Thanks Arron and James. James, i'm not aware of an "adjuster" anywhere in the shift linkage. Where is it? I know the cone things on each end of the rod. No adjustment there. Is it something at the shifter? I'm not being a smart ass, i really don't know... sorry. Roger |
Aaron Cox |
Aug 30 2005, 12:53 PM
first...its A A ron
second. a splined rod in the tunnel, meets the shifter. you can loosen the clamp on the shifter, and the rotate the rod left to right, and can move the rod forward and backward to ensure you hit all gears. lemme know if you need a pic. look straight down at your shifter. put the lever in third (this will bring the rod forward to where you can see it) and you will see a 13mm bolt head clamping the base of the shifter to the rod... AA |
Dr. Roger |
Aug 30 2005, 12:59 PM
AAron, =-) i'm bad... Thanks so much for the info! God will surely look down upon you and smile favorably upon you and your 914. (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Aaron Cox |
Aug 30 2005, 01:01 PM
736conver |
Aug 30 2005, 01:24 PM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
I chopped my rod in half, that sounds bad, and then inserted a wooden dowel. Worked great for mock up. The I cut a steel shaft the same length and welded it up. It is pretty forgiving with the adjustment in the tunnel.
Red-Beard |
Aug 30 2005, 09:14 PM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
The sleeve in the tunnel is for tail shifters. The adjustment for the sideshift is in the tunnel, near the shifter.
See here: http:\\home.san.rr.com\pb914\ |
SGB |
Aug 30 2005, 09:23 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
Hay AA
Is it ~w~e~i~r~d~ having that double letter thing going on? Makes me wanna say Ah-Aron. Like Le-Loyd. Y'know? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 10:02 AM |
