| rhodyguy |
Aug 31 2005, 03:45 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
getting started. try to tidy it up and put a bit of shine on it.
k Attached image(s)
| rhodyguy |
Aug 31 2005, 03:48 PM
how do i get these f.l. ends off the injectors? i'd prefer not to break stuff.
k Attached image(s)
| Eric Taylor |
Aug 31 2005, 04:56 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 909 Joined: 1-June 03 From: Bend, Oregon Member No.: 770 Region Association: Pacific Northwest |
If you lossen the clamp on the hose, you can fanagle the rail away from it, sometimes they are very tight, and if worse comes to worse you can take the little hose sections off and replace them with proper high pressure fi hose. They may look like they are on their tight , but they do come off if needed.
Eric |
| rhodyguy |
Aug 31 2005, 05:30 PM
oh no eric. they will be removed and new hose and clamps. is anybody missing a sparkplug socket?
| rhodyguy |
Aug 31 2005, 05:35 PM
it just seems as though it would be so much easier to replace the chts NOW. does it need anything special on the threads upon r&r?
k Attached image(s)
| TravisNeff |
Aug 31 2005, 07:04 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region
Nothing on the threads at all even antiseize, it'll fuck up the CHT readings so I hear
| rhodyguy |
Aug 31 2005, 07:35 PM
this engine cleaned up pretty easily for the initial crud off. a little pointy tool picking, shop vac and then the air nozzle. shop vac and comp running at the same time. what did you say? tomorrow i'll pick up some Oil Eater at costco and let it do it's magic. hose of with hot water and start reassembly. slight seepage on the rear main. so i'll add to the parts order tomorrow.
k Attached image(s)
| rhodyguy |
Aug 31 2005, 07:37 PM
this oily stuff is pretty superficial. the oil cooler was real clean. i'll use some berryman's and air to flush it well.
k Attached image(s)
| pete-stevers |
Aug 31 2005, 07:49 PM
Shinee Side Up Prep and Paint ![]() ![]() ![]() ![]() Group: Members Posts: 2,671 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest
looks good Kevin...if only you could have waited another month or two , i coulda sold you my 2.0, (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
| rhodyguy |
Aug 31 2005, 08:18 PM
asdf
| MarkV |
Aug 31 2005, 08:26 PM
Fear the Jack Stands ![]() ![]() ![]() Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
Mine is older. (IMG:http://www.914world.com/bbs2/html/emoticons/flipa.gif)
| rhodyguy |
Sep 2 2005, 04:04 PM
sprayed the engine down with full strength Oil Eater and let it soak. the hose is hooked up to the hot water faucet for the washer.
k Attached image(s)
| rhodyguy |
Sep 2 2005, 04:05 PM
rinse and repeat. damn near too bright when the sun is shinning. (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif)
k Attached image(s)
| rhodyguy |
Sep 2 2005, 04:09 PM
BONUS!!! ready to pull a few items off the 1.8 and start reassembly.
k Attached image(s)
| rhodyguy |
Sep 3 2005, 06:22 PM
well... while i'm in there.
k Attached image(s)
| rhodyguy |
Sep 13 2005, 05:25 PM
cleaned and powder coated. begin assembly tomorrow.
k Attached image(s)
| sixnotfour |
Sep 14 2005, 12:00 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,161 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
Now get those car parts out of the house , Yes Dear (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Lookin Good |
| jonwatts |
Sep 14 2005, 12:31 AM
no rules, just wrong ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
(IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif)
Is that the tin that came with the engine or did you have another set powder coated? Either way yer movin' fast~~~~~~~~~~~~~~~~ |
| sportlicherFahrer |
Sep 14 2005, 03:34 AM
Nothing to see here. ![]() ![]() ![]() Group: Members Posts: 1,124 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest
Damn Kev! Lookin good! Would love to hang around and help while you are doin some of the work and install so I can kinda see how it all goes together. Possible power increase in the future for me. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
| 1bad914 |
Sep 14 2005, 04:59 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 618 Joined: 6-May 04 From: Battle Creek, MI Member No.: 2,028 |
Very nice Kevin! The clutch will work great on that!
Lo-Fi Version | Time is now: 17th March 2026 - 10:11 PM |
