| mb911 |
Jul 14 2025, 04:04 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,723 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
Looking for as many setups and insight for those that have done it. Parts list are much appreciated.
| Chris914n6 |
Jul 14 2025, 07:57 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,527 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
which trans?
stock pedal or Tilton/Wilwood? Subaru swap? LS swap? Ferrari swap? |
| East coaster |
Jul 14 2025, 08:30 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,925 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None
Here’s my setup. It’s for my Suby conversion, but should be viable for any setup. Don’t score my welds (IMG:style_emoticons/default/smile.gif)
| sixnotfour |
Jul 14 2025, 08:35 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,169 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
| Larry.Hubby |
Jul 14 2025, 09:16 PM
Member who doesn't post much, but has a long time in 914s ![]() ![]() Group: Members Posts: 191 Joined: 24-November 04 From: Palo Alto, CA Member No.: 3,172 Region Association: Northern California |
This thread talks about some of the hydraulic conversions people have done, including mine:
http://www.914world.com/bbs2/index.php?sho...c=90342&hl= I have a 3.0 six with a 915 transmission in my car, but it's a '78 engine and trans, so I do have the over-center helper spring on the throwout mechanism at the transmission, and I added the helper spring down at the pedals as well to stay as close to stock as possible. The mechanical advantage can't be increased beyond stock without shortening the travel of the throwout lever, so I doubt you will get much relief from doing that before you run into inadequate clutch travel. |
| mb911 |
Jul 15 2025, 04:55 AM
| bdstone914 |
Jul 15 2025, 12:34 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,275 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@East coaster
You need to push the brake rod assembly onto the post and install the washer and cotter pin. Attached thumbnail(s) |
| ClayPerrine |
Jul 15 2025, 03:59 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Here is how I did the clutch master setup:
(IMG:http://www.914world.com/bbs2/uploads/post-1143-1555814683_thumb.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-1143-1555814691_thumb.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-1143-1555814703_thumb.jpg) I reversed the shaft in the pedal box. That put the arm at the other end, so the clutch master doesn't have to mount to the front of the tunnel. I ended up reworking the clutch master connection to the arm after driving it a bit. I changed it out for a clevis that went on both sides of the arm. I ended up changing the master cylinder for a different one to get it to disengage the clutch completely, but now it is way too heavy. Rick918S found a 944 master cylinder that will work with a Boxster/Cayman slave, so I am going to give that a try. |
| East coaster |
Jul 15 2025, 04:53 PM
| captain awesome |
Mar 23 2026, 09:31 AM
Newbie ![]() Group: Members Posts: 39 Joined: 4-July 24 From: Bella Vista, AR Member No.: 28,217 Region Association: None |
Here is how I did the clutch master setup: (IMG:http://www.914world.com/bbs2/uploads/post-1143-1555814683_thumb.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-1143-1555814691_thumb.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-1143-1555814703_thumb.jpg) I reversed the shaft in the pedal box. That put the arm at the other end, so the clutch master doesn't have to mount to the front of the tunnel. I ended up reworking the clutch master connection to the arm after driving it a bit. I changed it out for a clevis that went on both sides of the arm. I ended up changing the master cylinder for a different one to get it to disengage the clutch completely, but now it is way too heavy. Rick918S found a 944 master cylinder that will work with a Boxster/Cayman slave, so I am going to give that a try. Any word on a master that works better? I installed a 5/8 Honda master with my Boxster 5 speed and have difficulty getting into gear. Pedal is super soft and pick up point is just off the floor. Looking into a 3/4 but I keep seeing mention that the effort is too high even though that's the Boxster size. Hoping you might have the answer before I start trying to chuck useless parts at it. |
Lo-Fi Version | Time is now: 23rd March 2026 - 05:58 PM |
