SteveNMaine |
Member ![]() ![]() Group: Members Posts: 68 Joined: 12-August 24 From: Maine Member No.: 28,288 Region Association: None ![]() |
I just finished installing my 2056 and tested everything on jack stands. I was able to get all five gears and reverse, no problem.
When I lowered the car on the ground and backed out of my garage I was not able to get first gear. I did notice that the shift lever hits the base limiting how far back it will go. I have read most of the forums referring to adjusting the shifter and it seems that if I shift into 2nd gear, loosen the bolt, move the lever further forward that will give me more travel shifting back into 3rd and 1st gears. I did this and got 1st gear but it still has a tendency to pop out of gear. I am going to try to adjust it that way a little further. Am I on the right track? |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,204 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
SteveNMaine |
Excellent, thank you for the information. |
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,334 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
Jack Standz |
Senior Member ![]() ![]() ![]() Group: Members Posts: 524 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None ![]() ![]() |
One additional point, based on recent experience adjusting the shifter on a side-shifter transmission. And also, since you're putting this back on the road after having it on stands (transmission removed and reinstalled).
Sure, go ahead and replace all the shift bushings. But, DO NOT reuse the conical set screws (or at least use lock tight). Had one that didn't stay tightened and the one shift rod rotated inside the other one. You can't see the screw without pulling back the rubber boot. This makes it very hard to diagnose why things won't work. You can adjust the shift rod at the shifter all you want, but you'll never be able to shift into all the gears if the conical screw doesn't stay tight. Best wishes for getting it fixed. |
DC_neun_vierzehn |
Senior Member ![]() ![]() ![]() Group: Members Posts: 559 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region ![]() ![]() |
One additional point, based on recent experience adjusting the shifter on a side-shifter transmission. And also, since you're putting this back on the road after having it on stands (transmission removed and reinstalled). Sure, go ahead and replace all the shift bushings. But, DO NOT reuse the conical set screws (or at least use lock tight). Had one that didn't stay tightened and the one shift rod rotated inside the other one. You can't see the screw without pulling back the rubber boot. This makes it very hard to diagnose why things won't work. You can adjust the shift rod at the shifter all you want, but you'll never be able to shift into all the gears if the conical screw doesn't stay tight. Best wishes for getting it fixed. Cheapest I've found them is here: https://www.delawareporscheparts.com/oem-pa...ead-90142422901 |
Lo-Fi Version | Time is now: 8th August 2025 - 06:28 AM |
