whats the best mpg, that you have done in your teener |
messix |
Sep 12 2005, 10:46 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
on the a road run with the guys last month on back roads not even taken it easy i got 29.5mpg.
i'm trying something this tank while drivin to an fro to work, 8 miles of surface streets and a little freeway. short shift [edit; i ment skip shift] using 1st , 3rd, and 5th. all on flat easy roads. use brakes only not down shifting while decel. or stopping. its hard to not just row through the gears, but i'll try my best. |
Pugbug |
Sep 12 2005, 10:59 PM
Member Group: Members Posts: 449 Joined: 14-February 05 From: Victoria, BC Member No.: 3,604 |
Downshifting while decelerating does not use gas, but not downshifting wears brakes faster.
I haven't checked my mileage....but not using nearly as much as my pickup, so i don't care... Gassed up today... $1.29 for a litre of 92 grade! 4.55 litres per imperial gallon. Yikes! |
MattR |
Sep 12 2005, 11:12 PM
Advanced Member Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California |
smg914 |
Sep 12 2005, 11:13 PM
Sahara Beige Steve Group: Members Posts: 1,962 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None |
Back in the 70's on a trip from New Jersey to Lynchburg Virginia I went 550 miles on one tank full in my 1973 914 2.0.
lapuwali |
Sep 12 2005, 11:20 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
So, would you rather use brake pads to slow the car, or use the clutch to slow the car? SOMETHING has to slip, and brake pads are a lot easier and cheaper to replace than clutches... |
pete-stevers |
Sep 12 2005, 11:23 PM
saved from fire! Group: Members Posts: 2,642 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
Well....the worst gas milage I got was when a gas line poped of, the motor shut off, I tried to start the car a couple of times....yup the ground was covered in gas, a nice big puddle.....but yippie (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) ...no fire,
sorry for the (IMG:http://www.914world.com/bbs2/html/emoticons/hijacked.gif) |
JoeSharp |
Sep 12 2005, 11:27 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
Soo,,, What is this, most of us don't have wdorking odometers and the rest are too embarassed to say?????
:PERMAGRIN: Joe |
messix |
Sep 12 2005, 11:38 PM
if i understand l-jet f/i correctly the air valve senses fuel demand by how much air goes thru it. there for even when the throttle is closed there is still air going by the the throttle plate for idle. now under the high "vaccum" of decel. the engine is pulling more air passed the throttle plate even though its closed and this greater volume of air being sensed by the air valve and is firing longer fuel pulses to the injectors.
do i have this right or wrong |
redshift |
Sep 12 2005, 11:40 PM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
I dunno... I cheat.
I had this Saab, with all that information up to the second.. I loved doing the back side of hills in that thing... "Ahhh 143 miles per gallon.. I rock"... M |
redshift |
Sep 12 2005, 11:43 PM
If the TPS is at idle, that's how much gas is flowing... I am pretty sure. M |
TravisNeff |
Sep 13 2005, 12:00 AM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
With my recently transplanted injected 2056 I think I got in the neighborhood of 23mpg, mixed driving. Engine had sat for a year, then before that it sat longer - so I think I have some crap in the injectors, all other components check out fine (mps was tested and charted by Brad Anders).
With the injected 1.7 I got 34mpg going out to WCC. Gotta figure out why the mileage isn't that great in the 2.0 |
Type 4 Unleashed |
Sep 13 2005, 01:22 AM
CREATIVE TYPE lV ENGINEERING Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None |
After, all these years, collecting speedo's, I finally got one with a working odometer, and I just checked it the other day, 21.4, and thats with a 2.6 4 cyl with 48 Dell's and I would get more if I could keep my foot out of it (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif)
Gustl |
Sep 13 2005, 01:23 AM
914 enthusiast & historian Group: Members Posts: 11,522 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria |
if someone could tell me the conversion from liter to gallon I could calculate ...
normally my 1.8 L-Jet is about 8.5 - 9.0 liter on 100 km* but I didn't try to save on fuel yet - the teener is my hobby, not my daily driver (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) * 100 km = 62.5 miles (AFAIK) |
SpecialK |
Sep 13 2005, 02:39 AM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
My '74 2.0L got 50.7 mpg on a 180 mile leg of a trip from Chicago to St. Louis...all highway. After I fixed all of the vacuum leaks (IMG:http://www.914world.com/bbs2/html/emoticons/slap.gif) it got significantly worse (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) (time to start pokin' some holes in stuff!)
Hammy |
Sep 13 2005, 02:44 AM
mr. Wonderful Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California |
(IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) So do I downshift or not? (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
cbenitah |
Sep 13 2005, 03:13 AM
Protected by the Swedish Maffia Group: Members Posts: 848 Joined: 16-August 05 From: San Diego, CA Member No.: 4,597 |
1 L = 10 DL = 100 CL = 1000 ML 1 Gallon = 3.7854118 L Little help from Sweden (IMG:http://www.914world.com/bbs2/html/emoticons/drunk.gif) |
iamchappy |
Sep 13 2005, 06:22 AM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
I was able to get 72 while averaging 90 to 105 mph on a cross country trip.
BarberDave |
Sep 13 2005, 06:26 AM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
From Maumee to Effingham Ill. for the Fun Fest 37 MPG Return 39 MPG about 400 miles each leg all but 50 miles Xway. Iam leaving Fri For Kerrys event in Eastern Pa. Map Quest says 502 miles all turnpike will post results Mon. 1.7with small Webers 34's Dave (IMG:http://www.914world.com/bbs2/html/emoticons/slap.gif) |
Gint |
Sep 13 2005, 06:43 AM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Bay area to Denver, all highway, averaged 44 mpg in a 72 1.7.
Gustl |
Sep 13 2005, 08:00 AM
now that was really helpful (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) if my calculation was correct, my teener goes about 27.8 mpg - through Tyrolean mountains and so (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) I'd say not that bad ... |
Lo-Fi Version | Time is now: 7th June 2024 - 06:08 AM |
