Tail Light bulb replacement |
Tobra |
Sep 16 2005, 09:39 AM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
So I looked it over, it seems like you have to remove the lens to access the bulbs. I presume the assembly stays in place, and you just take off the lens, but it is not readily evident how to do so. What is the technique? Already searched and got the bulbs needed.
Thanks |
Porsche Rescue |
Sep 16 2005, 09:43 AM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
Remove the large white plastic "nuts" on the inside of the trunk. Carefully remove the lense.
goose2 |
Senior Member Group: Members Posts: 976 Joined: 30-March 05 From: Eugene, Oregon Member No.: 3,847 Region Association: Pacific Northwest |
to remove the lens, unscrew the white plastic knobs on the back of the tail light assembly
aircooledboy |
Sep 16 2005, 01:42 PM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
But, don't be surprised if some DAPO has previouly sealed the lense to the housing, in which case you are REALLY in for a treat. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif)
BTDT, many times. (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) |
djm914-6 |
Sep 16 2005, 03:07 PM
Happiness is: Getting on the road Group: Members Posts: 1,864 Joined: 6-February 03 From: Burlington MA Member No.: 248 Region Association: None |
I don't mean to completely hijack this thread but...
Once the cover is off, what bulbs does one use? I have a very tiny bulb next to the outside edge that i can't find a match for and even the others are a bugger to match up. Does anyone have a list of bulbs with todays numbers? |
Tobra |
Sep 16 2005, 11:05 PM
Right here for bulb numbers
Someone else looked these up, Thanks, BTW. What to use to seal lens to assembly, or are these seals still available? |
Lo-Fi Version | Time is now: 6th June 2024 - 10:16 AM |
