TACH PROBLEMS |
TACH PROBLEMS |
TINCAN914 |
Sep 17 2005, 07:02 AM
Summer's Commin... Group: Members Posts: 2,440 Joined: 18-August 05 From: Colorado Springs, CO. Member No.: 4,611 Region Association: Rocky Mountains |
I have posted this question before, so I apologize in advance.
I have a 74 1.8 I removed the instrument panel a couple of weeks ago to clean the gauges, as well as to sand and paint the panel. I began pulling wire and then realized that the smart thing to do would be to tage the wires to the corresponding terminal. Well I aparently tagged one or two wrong. My problem seems to be the tach. The gas gauge works, everything lites up, but the tach is not working. Dave has given me some sirection, but there are not any numbers or letters, or symbols on the back of these gauges. Vance sent some pics of his 73 with a 74 tach, but when I follow the wiring still no luck. I know it was working, but I can't figure it out. Does anyone already have a 74 torn out that can take some pics, or a very simple diagram showing terminals withthe corresponding colors? I have beengoing through schematics, but they are aparently to complicated for my feeble mind... Help anyone!!!!! |
lapuwali |
Sep 17 2005, 09:12 AM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
The tach will need switched power (black wire OR red/white wire), a ground (brown wire), and a signal (black/purple wire).
On the back of the tach, there's a plastic thing with three spade terminals on it. If you look closely at the plastic part, you'll see +12 +6 1 - on it. That stands for +12 (volts), +6 (volts), 1 (signal), and - (ground). There's no connector for the +6 terminal, and the list above is left to right, looking at the back of the gauge. There's probably a long string of daisy chained red/white connections behind the gauges, which are switched +12 to the gauges (fused). Connect one of these loose connections to +12, the leftmost terminal. There's also going to be a number of daisy chained brown wires, grounds, so connect that to -, the rightmost terminal. The black/purple wire connects to the terminal marked 1, next to the ground terminal. |
TINCAN914 |
Sep 17 2005, 09:27 AM
Thanks James...
Got the welder here now, so I will take a closer look when he's gone.. |
Cap'n Krusty |
Sep 17 2005, 11:10 AM
"Sirection"? Oooooohhhh, can I watch? Dunno what that is, but I wanna see it ..... The Cap'n |
TINCAN914 |
Sep 17 2005, 12:30 PM
It's not a pretty sight... Why the hell isn't there spell check on this thing???????!!!!! God knows I could use it!!! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 03:12 AM |
