Changing oil, hope someone is online, which plug is drain? |
Tobra |
Sep 18 2005, 02:07 PM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
Changing engine and tranny oil, tranny is two sorto allen head plugs on the driver's side, drain and fill(Near tranny axis) Under the engine, there is a round plate in the middle, similar to a type 1, with one bolt in the center. There is also a larger nu on the sump, just L of the round plate, which is the drain? |
bd1308 |
Sep 18 2005, 02:15 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
on tranny...bottom plug is drain
on engine...i do both, the hex screw in deal is the oil drain...but i also take out the strainer to clean that out too..... b |
Gary |
Sep 18 2005, 02:22 PM
Senior Member Group: Members Posts: 744 Joined: 12-January 03 From: Mount Airy, MD Member No.: 134 Region Association: MidAtlantic Region |
Take the fill plug out first. If you take the drain plug out first and then can't remove the fill you have an empty tranny...
bd1308 |
Sep 18 2005, 02:49 PM
good point....
rhodyguy |
Sep 18 2005, 02:58 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
the round plate covers the metal screen. hope you have the gaskets and crush washer. don't over tighten the bolt retaining the screen cover. the one on the pass side just forward is the drain plug. you don't have to disturb the cover just to change the oil.
k |
Tobra |
Sep 18 2005, 03:07 PM
Could not get tranny drain plug out, but added 300 ml of tranny oil. SO the big nut is the drain, and the smaller one holds in the screen, got it, thanks for the prompt response, I got a BBQ to go to.
Lo-Fi Version | Time is now: 11th June 2024 - 07:48 PM |
