Paint for valences |
Tobra |
Sep 19 2005, 08:55 AM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
What is the correct color for the front and rear valences on my car. I don't really mind if it is out of a rattle can, just want to pull the front one off, clean them both up, prime, paint and not have to deal with it again.
Dave_Darling |
Sep 19 2005, 09:11 AM
Satin black. Wurth underbody schutz is supposed to be the "perfect match" for CW types; most of us don't mind generic-o satin black rattlecan...
--DD |
Mark Henry |
Sep 19 2005, 09:33 AM
The rattle can stuff will chip and if you power wash it peel right off. So " not have to deal with it again" maybe a bit of a pipe dream. |
Trekkor |
Sep 19 2005, 11:33 AM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
I use Rustoleum's gloss black lacquer for my rockers and air dams.
I had the rocker professionally prepped and "rocker schutz" applied. The only place where I'm having problems is on the leading edges where the gravel is blasting the rockers to bare metal. ( sticky tires throw gravel ) KT Attached image(s) |
rhodyguy |
Sep 19 2005, 11:52 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
krylon semi-flat black. it holds up pretty well.
k |
Howard |
Sep 19 2005, 12:00 PM
Incontin(g)ent Member Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None |
Purists hate this, but for a driver or track car, I really like it. It does not come off ANYTHING so be careful. Mine were a mess.
Herculiner Before Attached image(s) |
Howard |
Sep 19 2005, 12:01 PM
After. Hides lots of little imperfections.
Attached image(s) |
Aaron Cox |
Sep 19 2005, 12:03 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
damn howard - those rockers were fuglee!
IronHillRestorations |
Sep 19 2005, 12:10 PM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Dupli-color semi-gloss black is a good choice for OEM appearance, and is usually easy to find. I mix standard gloss and flat implement enamel to get the low gloss finish I want, and add some hardener, this is for a spray rig though.
As with any painting, the prep work is the key to a good finish and holdout. Wash with soap and water first, clean with Prep-sol or Klix 88 before any sanding. You want to make sure you remove any and all grease, wax, and silicones before you start sanding, or you'll just push that kind of junk all over the part and have problems. |
Howard |
Sep 19 2005, 12:12 PM
Hey, that was after I ground off the bondo, filled the holes and hammered the crap out of them. This if fuglee..
Attached image(s) |
Tobra |
Sep 19 2005, 01:25 PM
Thanks for the replies, idea popped into my head, how about powdercoating? That stuff is pretty bulletproof, and I think it can be done in a semi-glossy finish.
Aaron Cox |
Sep 19 2005, 01:31 PM
got an oven that big??? (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) |
Mike D. |
Sep 19 2005, 01:37 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
I took mine to Pyramid powder coating and got the satin black, looks great...
-Mike D. |
Dave_Darling |
Sep 19 2005, 02:36 PM
You got that right!!! (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) Never get it on your Hootus.... --DD |
Midtowner |
Sep 19 2005, 08:35 PM
Ooooo! Group: Members Posts: 652 Joined: 21-December 04 From: Sunnyvale, CA Member No.: 3,316 Region Association: None |
Hootus? (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Hammy |
Sep 19 2005, 08:47 PM
mr. Wonderful Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California |
I sanded mine down and then put on black rattlecan primer... Then a clear coat sealer over that. It looks better than "okay" and it has yet to chip. Actually it's held up really well (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) but I'm sure it'd easily chip if you go offroad (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) But how often do ya do that (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif)
Tobra |
Sep 19 2005, 09:22 PM
Why not put like a little mudflap in front of it, paint the flap with bedliner and clip it onto the front of the rocker, protect the rocker, and the whole car. |
Trekkor |
Sep 19 2005, 10:15 PM
Mudflaps, eh? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
A guy who a/x's his nice 914 regularly, protects all the inner fender surfaces and rocker leading edges with blue tape. KT |
jonwatts |
Sep 20 2005, 12:24 AM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
SEM Chip Guard will give you the correct look. To apply it properly you want to lob it onto the rockers like you're spraying silly string. Play around with it and you'll get the idea.
Tho I like the herculiner approach, that might be better if you're running shlicks. |
Lo-Fi Version | Time is now: 1st June 2024 - 12:36 AM |
