Glue residue removal question, (Racer tape) |
campbellcj |
Aug 4 2003, 09:00 PM
I can't Re Member Group: Members Posts: 4,545 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
OK, at the risk of sounding like a question on the 911 board of "that other list", what is a good chemical or technique to use to get rid of racer tape glue residue and/or black tire marks from (a) painted body panels and more importantly (b) plastic lenses?
I have had good success with "Bug & Tar Remover" on painted panels but that, Windex and Simple Green haven't budged the crap on the turn signal lenses. Obviously I don't want to melt the plastic so have been afraid to try Brad's two favorite concoctions: Goof Off or Brake Cleaner. |
Brad Roberts |
Aug 4 2003, 09:03 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
No No.. dont use them together..
Goof off works the best. Ask Sean and all the others who helped us clean the MoM GT3RS. They buy it by the gallon and stick it in a larger spray bottle. Works great. B |
vortrex |
Aug 4 2003, 09:10 PM
Senior Member Group: Members Posts: 1,687 Joined: 24-December 02 From: SF, CA Member No.: 4 Region Association: None |
I don't know where you can find this, but my mom's a nurse and brings home small bottles of this pink liquid they use for cleaning the sticky leftovers of bandages off people. it works well and is gentle, would be great for your lenses. I have some in my car now, I will look at the name tomorrow if you want it.
MarkV |
Aug 4 2003, 09:12 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
WD-40 (IMG:style_emoticons/default/laugh.gif)
Brad Roberts |
Aug 4 2003, 09:13 PM
Nah...
You need something that breaks down the proteins of the "bug bodies".. which Goof Off does also. B |
Aaron Cox |
Aug 4 2003, 09:14 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
QUOTE(MarkV @ Aug 4 2003, 08:12 PM) WD-40 (IMG:style_emoticons/default/laugh.gif) OH NO! another car has been totalled!!!!! |
vortrex |
Aug 4 2003, 09:15 PM
there are bugs in CA?
seanery |
Aug 4 2003, 09:21 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,852 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
We clean a lot of cables when we do live events that get covered in gaffers tape (which is similar, but not quit the same).
I use tape to get tape goo off. You just kinda use the friction of the tape pulling on the goo. When you get most of it, then do goof off, it does work really good for the rubber. |
VegasRacer |
Aug 4 2003, 10:05 PM
ELVIRA Group: Benefactors Posts: 8,511 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
I can confirm that goof off will clean the tape residue from your turn signal lenses without damaging the plastic.
Attached image(s) |
campbellcj |
Aug 4 2003, 11:21 PM
Awesome...Goof Off it is then. I have a big can sitting here; somehow I got the idea it would f* up the plastic.
I don't even know why I still tape the turn signal lenses. I have not noticed that in the rules but it is a very common practice and seemed like "the thing to do". If one broke it would seem very unlikely to cause damage to other drivers. Now a big 911 glass headlight would be a different story... That thought just reminded me that a Z06 Vette got its windshield smashed at the last OTR event; some guy apparently left a hockey-puck style jack plate/pad stuck to the bottom of his car and it subsequently separated itself at 100+mph on the track...OOPS. Safety glass held together fine though. I am switching to semi-permanent vinyl numbers so thank god I won't have to deal with mass quantities of racer tape to hold on my old POS magnetic gumballs anymore. Although who knows what will happen if/when I remove the vinyl ones (IMG:style_emoticons/default/idea.gif) |
Brad Roberts |
Aug 4 2003, 11:26 PM
We use the really thick vinyl numbers... you can reuse them 2-3 times. Wax the area's where they will sit and they will come off real easy (slowly)..
B |
Jeroen |
Aug 5 2003, 05:06 AM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
The vinyl stickers won't hurt your paint.
Worse thing that can happen is that when you take them off, the paint underneath 'em is shineyer than the rest of the car (IMG:style_emoticons/default/biggrin.gif) cheers, Jeroen |
Maine914 |
Aug 5 2003, 09:46 AM
Member Group: Members Posts: 99 Joined: 30-January 03 From: Maine Member No.: 215 |
What works best on the underside of the targa top? The headliner on mine is long gone, and there is a bunch of old dried glue left. What's the best product to get that off?
Thanks. |
seanery |
Aug 5 2003, 10:00 AM
try mineral spirits.
Lo-Fi Version | Time is now: 23rd May 2024 - 01:19 AM |
