> more CV questions
mightyohm
post Sep 23 2005, 12:38 AM
Two questions;
1. which side should the "ridged" side of the ball cage face when installed? towards the axle or away? I think it is away from the axle but I didn't take a good enough 'before' picture to tell (oops).
2. One of the used joints I bought in Ventura is different than the others. It has larger balls and a lot more axial travel than the rest. It shows some wear but not extreme spalling like on the ones I am replacing. Is this a rebuilt joint? Is more axial play normal in rebuilt joints?
Thanks in advance for any help. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
TravisNeff
post Sep 23 2005, 01:13 AM
I believe they go away from the axle. I too have found a couple CV's with different cage and ball sizes, my guess they are rebuilt units - and yes lots of play.
mightyohm
post Sep 23 2005, 01:18 AM
The joint is still fairly "tight", nowhere as loose as the ones I am replacing. I think I'll put it on and see what happens.
(IMG:http://www.914world.com/bbs2/html/emoticons/burnout.gif)
TravisNeff
post Sep 23 2005, 01:23 AM
These were better than the ones I replaced, but still not that great, so far so good!
post Sep 23 2005, 09:59 AM
Resident German
QUOTE (Travis Neff @ Sep 23 2005, 12:13 AM)
i dis-agree ...
the "ridge" side of the inner race is what slides on the axle shaft, the flat side faces towards the outside where the clip goes ...
(IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) Andy
914werke
post Sep 23 2005, 10:17 AM
(IMG:http://www.914world.com/bbs2/html/emoticons/thisthreadisworthlesswithoutpics.gif)
mightyohm
post Sep 23 2005, 11:03 AM
Andy are you talking about the inner race or the cage that retains the balls?
I am referring to the cage - the thing that goes in between the two races.
Wish I had taken a pic last night. Will take one tonight.
bondo
post Sep 23 2005, 11:06 AM
When working on multiples of things, never have all of them apart at once. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
This is especially important when working on drum brakes, something we fortunately don't have to worry about on the 914.
dmenche914
post Sep 23 2005, 11:13 AM
small balls may indicate a VW CV joint. What size balls do you have??? HA HA HA. Small balls in the correct CV should be no problem, although the load rating might be less. I had a mix of small balled and large balled CV's on one 914, niether one gave any problems driving a stockish 1.7 car.
good luck
Grimstead
post Sep 23 2005, 02:18 PM
Cheaky Monkey
Jeff,
My engine & tranny are out if you want me to take some pictures of my CV's.
Just let me know.
post Sep 23 2005, 04:06 PM
Resident German
QUOTE (jkeyzer @ Sep 23 2005, 10:03 AM)
uhm, my cage dosn't have ridges. it's symmetrical ...
(IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Andy
mightyohm
post Sep 23 2005, 07:55 PM
Here are the ridges. The other side is smooth.
Ignore the fact that the center race is installed upside down.
post Sep 23 2005, 09:12 PM
Resident German
QUOTE (jkeyzer @ Sep 23 2005, 06:55 PM)
ok, i'm looking at my 944 CVs as we speak and the cage has no ridges on either side. perfectly smooth ...
Aaron Cox
post Sep 23 2005, 09:59 PM
Professional Lawn Dart
QUOTE (SirAndy @ Sep 23 2005, 08:12 PM)
i think jeffs are 914/4 (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
914werke
post Sep 23 2005, 10:27 PM
I just chked my /4 CV/s that I had dissasembled and shor' nuf, I see what jeff is describing but danm if I can see what differance it would make? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
mightyohm
post Sep 24 2005, 02:24 PM
These are 914-4. I think the inner race only fits into the cage from the ridged side, because the opening is a little larger. So there is a difference...
Cap'n Krusty
post Sep 24 2005, 03:05 PM
Cap'n Krusty
QUOTE (jkeyzer @ Sep 22 2005, 10:38 PM)
Two questions;
In the remaining pile of CVs here at the shop, there's a mix of large and small sizes. As I recall, the new ones I sold last spring were the same way. Could be from different production runs. Porsche calls Lobro and asks for thickness, spline count, and OD. As long as the degree of angular movement is sufficient, the actual design doesn't really matter. The Cap'n
- Lo-Fi Version Time is now: 19th July 2025 - 07:17 AM
