Headlight weirdness |
jsteele22 |
Oct 2 2005, 01:53 PM
Senior Member Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 |
As if I don't have enough to worry about just now... I went for a ride last night and found 2 strange things w/ my headlights.
1) When headlights are on, turn signals do not work. If I turn lights off, signals work fine. Emergency flashers work fine either way. All fuses are good. and the weird one... 2) My left headlight works fine on high or low beam. The right one appears to do the exact opposite ! The (right) high beam points down close, the low beam point far away. Fortunately, it points enough to the right not to blind oncoming drivers. Is this something that can be adjusted ??? TIA, Jeff |
Dr. Roger |
Oct 2 2005, 02:48 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
just switch the right headlight wires from high to low and low to high.
i have no idea about the rest. sorry. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Roger |
McMark |
Oct 2 2005, 02:51 PM
Yeah sounds like either the right headlight wires are swapped either at the fuse panel or at the connector that plugs into the bulb.
Gint |
Oct 2 2005, 05:59 PM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
It's that RRc award left headlight cover. The right headlight is jealous.
These guys sound like they might have figured it out for you Jeff. Any luck? |
Lo-Fi Version | Time is now: 1st June 2024 - 09:47 PM |
