> Would anyone happen to have this part?, view picture:
dlo914
post Oct 3 2005, 03:27 PM
Whatchu' lookin' at?!?!
the outboard motor mounts that hold up the engine bar:
Aaron Cox
post Oct 3 2005, 03:38 PM
Professional Lawn Dart
how did you destroy yours??
Call pelican... or find a parts car.... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
ClayPerrine
post Oct 3 2005, 03:39 PM
Use a pair of these. Competetion motor mount on the Bird.
mount them with the boss pointed up, and the side shifter bar will bolt right up.
dlo914
post Oct 3 2005, 03:51 PM
QUOTE (Aaron Cox @ Oct 3 2005, 01:38 PM)
both nuts & bolts holding the engine bar in place were heavy seized (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
michel richard
post Oct 3 2005, 04:02 PM
Or make some. Buy some square steel tubing of the right size, saw one side off. Saw and file to shape. Drill holes.
dlo914
post Oct 3 2005, 04:13 PM
QUOTE (ClayPerrine @ Oct 3 2005, 01:39 PM)
would you happen to have the exact link? instead of the link to the image...
dlo914
post Oct 3 2005, 04:14 PM
QUOTE (michel richard @ Oct 3 2005, 02:02 PM)
hmm good idea!
machina
post Oct 3 2005, 04:16 PM
QUOTE (ClayPerrine @ Oct 3 2005, 04:39 PM)
won't that move the front end of the entire drivetrain upwards about .75" ?
michel richard
post Oct 3 2005, 04:20 PM
QUOTE (dlo914 @ Oct 3 2005, 02:14 PM)
hmm good idea!
I'm cheap and the hardware store is the cheapest (and quickest) source for parts! Just make sure you buy a new hacksaw blade. They're cheap too, and a new one will make a world of difference. Get 18 or 24 teeth per inch, no more.
dlo914
post Oct 3 2005, 04:30 PM
QUOTE (michel richard @ Oct 3 2005, 02:20 PM)
hmm good idea!
sadly, ive only got a jigsaw. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) BUT a metal cutting blade on that thing works just fine. Does anyone know the size and length of the bolts that are required for this application?
Dave_Darling
post Oct 3 2005, 05:17 PM
914 Idiot
Mister PET says:
N 010 472 4 BOLT HEX-HD.M 10 X 85 (that's the big bolt through the middle)
900 075 085 02 BOLT HEX-HD.M 8 X 20 (those are the little ones through the sides of the mount)
--DD
michel richard
post Oct 3 2005, 05:19 PM
QUOTE (dlo914 @ Oct 3 2005, 02:30 PM)
hmm good idea!
Get a hand hacksaw. They're cheap. And with a sharp blade, with a low tooth count, it's amazing how quickly you will saw through square tubing. I'm sure people don't use hand saws only because they've never used one with a good fresh blade.
dlo914
post Oct 3 2005, 05:32 PM
QUOTE (Dave_Darling @ Oct 3 2005, 03:17 PM)
Mister PET says:
--DD
thanks Dave!!! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
dlo914
post Oct 3 2005, 05:33 PM
now for sure im gonna make these mounts rather than spending $20+ on a set (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
dlo914
post Oct 4 2005, 02:01 AM
could someone get the dimensions of piece #9? TIA! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Aaron Cox
post Oct 4 2005, 09:36 AM
takle a piece of thick paper....
put it against theouter body mounts... and trace the 2 small holes.
then MEASURE the distance, center to cener of these holes.. and mark the middle. now drill your big hole
Triaddave
post Oct 4 2005, 09:48 AM
$20+ seems alot easier to me. i'm sure i have a box load of them. for the +, i'd even run them through the bead blaster, you pay shipping.
dbledsoe
post Oct 4 2005, 11:10 AM
Mutineer
I PM'd you that I have the mounts minus the bolts but got no reply. Perhaps I should have mentioned that they would only cost you the actual postage. (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
dlo914
post Oct 4 2005, 12:27 PM
QUOTE (dbledsoe @ Oct 4 2005, 09:10 AM)
how much for shipping? (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
dbledsoe
post Oct 4 2005, 02:21 PM
Mutineer
QUOTE (dlo914 @ Oct 4 2005, 12:27 PM)
I'm pretty sure that Priority Mail would be $3.85. They don't weight much. I can dig them out tonight box them and calulate shipping if you let me know your zip code.
- Lo-Fi Version Time is now: 19th July 2025 - 03:31 AM
