Pin Clips for ebrake cables...? |
fiid |
Oct 17 2005, 04:31 PM
Turbo Megasquirted Subaru Member Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
Hey,
I'm missing one of those little clips that keeps the pin that goes through the ebrake cables from dropping out. Where would one get a replacement...? TIA, Fiid. |
ArtechnikA |
Oct 17 2005, 05:48 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
it's N.012.645.2 if you decide try at a dealer or Pelican or such.
but i just drill the pin 1/16" and run a loop of safety wire through it (my cars are drivers, not concours contenders, and i always know where the spool of safety wire is...). you could also use a cotter pin. the factory clip is probabky really quick on the assembly line tho. |
fiid |
Oct 17 2005, 06:58 PM
I'm trying to keep the car original.
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Not really - thanks for the tip - I can't believe I didn't think of drilling it... DOH! |
mightyohm |
Oct 17 2005, 07:01 PM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
there isn't much space to drill there. you'll have a hard time fitting a cotter pin unless it is truly tiny and you are very accurate with the drill bit!
Lo-Fi Version | Time is now: 10th June 2024 - 11:30 PM |
