still more oil filter troubles, nipple size? |
shaggy |
Oct 30 2005, 08:40 PM
mechanic/welder/fabricator Group: Members Posts: 702 Joined: 26-September 05 From: Gilbert, AZ Member No.: 4,869 Region Association: None |
on the oil filter assemble
the nipple that the filter attaches to what size and thread is that? it looks like i just cross threaded id like to get a die and run it over the nipple and correct those threads i have to go to school tomorrow morning though and my dad (flatvw) is gonna try to find a die for that so i kinda need to know the size and thread tonight if at all possible thanks for all the help so far -jim |
Flat VW |
Oct 31 2005, 10:03 AM
Illegal Soapbox Derby Racecar Group: Members Posts: 1,692 Joined: 13-November 04 From: Phoenix, AZ Member No.: 3,105 |
(IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) , (IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif) For the die size......
John |
Demick |
Oct 31 2005, 10:07 AM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
3/4-16
SLITS |
Oct 31 2005, 01:38 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
See other thread...it's aluminum....have you ever successfully "restored" threads in aluminum (without a timesert or helicoil)?
Just a question............ |
Flat VW |
Oct 31 2005, 01:49 PM
I hate "pointed" questions (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) ................... John |
Flat VW |
Oct 31 2005, 01:58 PM
An "outside" helicoil, and then we could get custom made oil filters! (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
J |
bd1308 |
Oct 31 2005, 02:05 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
or just nix the stock oil filter setup, tap for some nipples at the same location, run some rubber lines or whatever you want to a bug oil filter setup....seen it done, looks good.
b |
ClayPerrine |
Oct 31 2005, 02:19 PM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
If you dimple the oil cooler next to the bolt head you can get a 1/4 drive 13mm socket over the bolt for the oil filter adapter.
Then remove it and replace it. BTDT.... But no one will believe that I can do it...... |
Flat VW |
Oct 31 2005, 02:51 PM
Come over here and prove it Clay! John P.S. betcha' can't (IMG:http://www.914world.com/bbs2/html/emoticons/Yack.gif) |
ClayPerrine |
Oct 31 2005, 02:53 PM
I am back in Fort Worth. Are you going to pay for the plane ticket? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Aaron Cox |
Oct 31 2005, 02:57 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
just drop the motor (1hr)
pull some of the surrounding tin and front cover (20 min) pull engine bar (10 min) SWAP out OIL FILTER console ( 20 min) instalation is the opposite of removal. AA |
bd1308 |
if you can get it off John....i'll give you a filter bracket. b |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:13 PM |
