OMB_Godfather |
Newbie ![]() Group: Members Posts: 49 Joined: 19-September 05 From: Bakersfield, CA Member No.: 4,823 ![]() |
Got a question. Can these starters heat up to the point of not bein able to turn the car over. I took a 150 mile trip and when i got home my car wouldnt turn over unless i bumped it off the compression stroke of the current cylinder. I was wondering if it was just cause of the long trip or is my starter goin kaput
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
As with all electrical wiring, heat increases resistance and the answer would be YES
Old wiring, dirty contacts, corroded battery cables, etc. Personally, I like the aftermarket Yappanese gear reduction starters with the new nose...$120 - $200 depending on where you buy them. |
anderssj |
Dog is my copilot... ![]() ![]() ![]() Group: Members Posts: 1,666 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region ![]() ![]() |
My car had the same problem for years--even after replacing the starter with a tilton reduction-gear unit and adding a hot-start relay. After that I went through all of the steps listed on the pelican site and added a NOS + battery cable. The "real" fix was replacing the woven ground strap between the trans and the underside of the trunk--at least no problems since then (knock on wood).
Hope this helps |
OMB_Godfather |
ok just kidding htat wasnt the problem. my alternator doesnt put out enough juice to recharge my battery while im running the stereo while driving. does anybody out there make an alternator taht puts out more power?
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
mine does fine...I even had a amp on it.
check your voltage regulator. b |
SLITS |
Yes, there are speciality rebuilders that will do it....but generally no one wants to pay the price. |
balljoint |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,000 Joined: 6-April 04 Member No.: 1,897 Region Association: None ![]() |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,912 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
You can always put a 72- on 911 starter on and forget all that hot start fix. The bottom line is the original starter is .8 hp. Porsche realized that had a problem and went to 1.5 hp starter for the 911.
You need to also check all the other stuff mention too. |
OMB_Godfather |
also would a bad regulator cause my car to buck so bad that the engine actually cuts out for a second or 2?
SLITS |
TPS.....common problem of bucking....dirty / worn traces....fuel pump loses power momentarily. |
Tom Perso |
Crazy from the Cold... ![]() ![]() ![]() Group: Members Posts: 647 Joined: 8-August 03 From: Kalamazoo, MI Member No.: 1,003 ![]() |
Just run a GM 1 wire alternator in place of your stock one. Takes a little fab work, but it fits.
(IMG:http://www.qtm.net/~persot/912/alternator5.jpg) (IMG:http://www.qtm.net/~persot/912/alternator2.jpg) Tom |
Lo-Fi Version | Time is now: 17th June 2024 - 11:36 AM |
